Figjam's Swamp Cooler
101,516
601
37
Posted
Introduction: Figjam's Swamp Cooler
This is a rendition of figjam's solar Swamp cooler. it works pretty well and is great for keeping you cool when you are in the hot hot heat! This is a great piece of equipment have when you want to be able to cool things down while you are camping or at burningman (like I will be!).
Step 1: Gather Your Gear
Things you will need are pretty simple.
- submersible pump ($9.00): you can find them at your local hardware store. I went to harbor freight and they had a few to choose from! figjam's version uses a solar pump which is 12 volts and pumps about 42 gallons per hour. I loved the idea of having it be completely solar, but when I tried it out, there wasn't much power going through it, and if there is any over cast, it won't work at all. and for 20 bucks i didnt think it was worth it.so I opted for one that I can plug in that I'd 120 volts.
- cooling fan ($7.00): I bought this at Frys. it's a 12 volt 120 mm fan and goes at about 96 cfm. it pretty much means the pumping power. There are cheaper and different ones you can buy out there. I picked this one bc I was going to splice it to the solar pump, but when there wasn't enough power going to it like I wanted it to, I found a 12 volt ac adapter that worked perfectly for it!
- homedepot bucket ($7.00): I bought the bucket and the lid because it's the perfect travel size. Figjam drilled 2 inch holes into the sides, but I just did 1 inch ones and had more of them for air to get into the bucket.
- cooling pads (9.00): homedepot has some and they are pretty cheap. I bought one sheet which was 28th I think. be careful when cutting these because they get messy!
- hose and T connector ($4.00): again homedepot lol. I got these in the lawn and garden area. It's a 3/8 diameter hose and same for the T connector. you are just going to have to cut to fit.
- drainage hose pieces ($14.00): the size is about 4 inches for this. It fits completely over where the fan goes and makes for good air flow.
Step 2: Do the Dang Thing!
1.First thing I did was drill the holes in the bucket. I placed them pretty close to each other and made sure I had plenty of them to go around.
2. cut the cooling pads. I cut them in different sizes. The first is 33 inches by 13 inches. it should let it fit perfectly in your bucket with out overlapping. The second piece should only be 24 X 13 inches. and you will roll this one in tight with the original.
3. cut the drip hose to size, and make it make a circle. This is for the water to floe from the pump and drip into the cooling pads. now you're gonna have to poke holes into the circle of the hose. I had a soldering iron and was able to burn the holes with great ease.
4. connect the hose to the pump. I wanted to make sure the hose and pump worked properly so I tested it out to make sure that everything worked. yay for me!
5. fan and lid. first thing i did was took a marker and traced the inner circle of the drain pipe. After getting the size and spot of where I wanted it, I cut out the piece of plastic from the lid. I screwed the fan on the bottom of the lid so I could save room and have the fan pump the air directly out of the bucket. I took the fan and was able to splice it to the ac adapter with ease.
6. Drain pipe. The pipe and connector fit perfectly into each other. After I was able to get them done, I just glue the pipe to the topside of the bucket lid. i made sure it covered the whole hole and that the fan would only be pumping into the pipe.
Step 3: That's It!
Make sure you test it out and use clean water. but it works perfectly and since mine need to be plugged in, I just use my solar portable generator that I built to power it.
hope you liked it, and have fun out there!
  • Science of Cooking
    Science of Cooking
  • Pocket-Sized Contest
  • Spotless Contest
    Spotless Contest
36 Comments
Would reversing the fan and pushing the air into the bucket and forced out through the pad make this work any better? I'm asking because I designed a similar system using a 48qt cooler and an inline fan pushing air into the cooler and out through a series of holes i drilled.
It is more efficient to pull the air through the pads. Swamp cooler on rooftop houses do the same, pull in thru pads. Also a propeller fan is three times as efficient as a squirrel cage fan, uses 1/3 the power for the same cfm.
A solar panel would have to have an output HIGHER than the amperage required for dc use. 12vdc requires 10 times the power that you get from 120vac. Also you'd better have four times as many 1" holes as 2" holes to flow the SAME amount of air.
I'll be at the burn this year too. Where will you be getting 120v on the playa?
You get 120v from the sound camp that is near/next to your plot. Bring a 100 foot cord, happy brownies or other sundry gifts, and see if they mind you plugging into their generator :)
I've actually built a solar generator. I will be posting an instructable on that prolly a little later today.
I tried to reply to specific comments below, the one about adding ice for my latest comment.
and the one about how big a solar panel for the latter comment. Instructables wasnt working right, I'll try and move them later: Be cool! Ha.
Not sure that is the case, and I sure want to know. if the h20 is cooler but not ice will that mean more evaporation perhaps even cooler evaporation by the warm dry air flow through and over the wicks, I believe so. of course a chunk of block ice wouldn't wick.
Warmer water well the closer the water is to the ambient temperature less cooling.....correct?
The drier the air the better, this I know.
Some expert schooled in the sciences better that I please give us the science (outside of the relative humidity. will ice water work better at cooling in an evaporative cooler that water x degrees below ambient temperature or is there some ideal gap for the evaporation point of water......I'll try both ways on my swampy for a proof is in the pudding response.
Without having profound electrical knowledge. a motorcycle battery and a 10 to 20 watt solar panel should do the trick. there is a nice price point on 50 watt solar panels and they are a convenient size. so why not.
You can get the numbers you need off your two "appliances" your fan and your pump and match that too your panel/ batts. I'll post my numbers. Please correct me if I'm wrong with your best nice folks, but you can not really oversize your battery, you just need enough electricity from your panel to charge what your swampy and??? are drawing factoring in for losses. I have a feeling there is a balance here to be achieved: too much water pumping over the wick: not enough evaporation. too many cfms of air could be too much evaporation of just defuse the nominal cooling?????? to powerful a fan in a small tent or hexayurt might be uncomfortable.....noise from a fan too small or big yet another consideration.
Was going to use a 4 inch inline fan and may in the future with a fan muffler.
EUREKA! for more efficiency why not have a drip swampy with no aquarium pump?
there must be a way to get optimum drip and and have but a bit of water to pour up higher when not evaporated, or even to have flow stop w/o power. Ay yi yi, I'll post if achieved.
On amazon and else where there are solar submersible pumps that come with a 5-10 watt panel, it may be that that would run the fan too and if you just want a daytime solution you could skip the battery "bank" perhaps. there are some decent battery operated fans that also will run off 12 volt. one could mount one of these and use rechargeables.
A nice jumper pack in conjunction with a solar panel is a great way to go. This is how I run my ARB fridge freezer which draws far more than a small DIY swamper. Also ideally if you are "boondocking": you want you place of rest in the shade and your panel in the sun, so you want long leads of the correct gauge or other portability.
