Filament Free Xyz Jr Printer
2,032
11
6
Posted
Introduction: Filament Free Xyz Jr Printer
Filament free xyz jr printer
Step 1:
Tag run to zero. Unable to print
After slicing you will be able to see gcode.
Step 2:
Edit hghlighted lines to "=0"
Step 3:
After you edit gcode you will be able to print.
Link to download xyzware advance http://www.soliforum.com/topic/12741/xyzware-advanced-mode/
Happy printing on non xyz filament....
    • Space Challenge
      Space Challenge
    • Microcontroller Contest
    • Spotless Contest
      Spotless Contest
    6 Comments
    I figured it out!!!!!!!! Also You must edit line ;extruder = 0
    And the job is done....
    Happy printing ....
    I came to fast to a conclusion. I got spool error after it transfer the model and start printing. The point is I started a print which required 4 m of filament and I had only 1.5 m left. After I applied the trick above it stated print and finished it even after the spool run out while printing. So I assumed the fix would work.. something worked that let the printer carry on writing on the tag even after it run out of filament to "0". I think there must be a way.. perhaps guys you ca help?
    Hi there I would like some assistance as my Da Vici
    JR does not print it keeps on saying the spool is empty. I Have tried it via usb and via the sd card and it does not print. Here is a
    copy of the gcode file I use
    Problem solved
    http://www.soliforum.com/topic/16565/updated-da-vinci-jr10-fw233-print-after-nfc-chip-run-to-zero/
    hi there,
    i followed all steps but unfortunately i cant load the fillament. i can i do this?
