This ring uses brass micro screws and nuts to quickly and permanently attach stacked elements. These tiny screws add a bit of mechanical detail to your designs. The filigree pieces are flattened and bent to shape before being screwed together. The nuts used to fasten the screws are on the back of the design and you’ll finish the ring by sanding them smooth for a comfortable fit.
Ingredients:
- 1 naked brass filigree butterfly
- 1 antique brass large dapped filigree oval, 35x42 mm
- 1 vintage watch face, approx. 25 mm (clip off any prongs on back using flush cutters)
- 1 vintage plastic flower, 14 mm
- 1 medium splat charm, 15 mm
- 2 brass micro screws and nuts, ¼ inch
Tools:
- Flush end cutters
- Flat nose pliers
- Ring mandrel
- Rawhide hammer
- Steel bench block
- Rubber bench block
- Jewelers needle file set
Remove these ads by
Signing UpStep 1Flatten Oval Filigree
6
comments
Add Comment
TorAngel
says:
Add Comment
