3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Filling Sandbags the Easy way, with Sandbag Tubes
Sandbags are still the best way to put up a quick dike in times of need. They are useful for many things, but the main focus of this is for those fighting floods. It's easy to get a lot of sand delivered quickly, sandbags themselves are cheap, and with a little labor, anyone can protect their home.
Filling the sandbags is the bulk of the work; holding the bags while someone shovels is time consuming, back breaking and tedious. There are many inventions that can help with the process, but most of the ones that work well are expensive.
The Sandbag Tubes are a cheap, simple to make, tool that will reduce the amount of effort required to fill bags and speed up the process. Anyone can use them and they can be used over and over. Because they are so cheap and easy, many sets can be made and used simultaneously.
Advantages include-
- No one stuck bent over holding bags
- All participants can shovel
- Does not require lifting the shovel any higher than necessary
- All bags filled correctly and consistently (no heavy/light bags).
- Faster than many machines
Step 1Buy the Materials
Buy the Materials
First you need to make sure you have all the required parts.
Parts needed:
   - One 6" x 10' thin walled sewer pipe
   - Two 8 foot 2x4s
   - 1 5/8 construction screws (for attaching tubes)
   - 3" construction screws or nails (for frame assembly)
   - 2' 5" x 1'5"  1/4" or thicker plywood (optional but recommended)
Tools Needed:
  - Saw to cut the tubing and 2x4
  - Drill bit to pre-drill the holes for screws (right angle drill is easier)
  - Powered screwdriver
  - handheld jigsaw or router for cutting plywood (for optional top)
31 comments
May 25, 2010. 12:02 PMdigimancer says:
 Add a lip to the outside edge.
Jan 24, 2011. 2:06 PMBroom says:
... which is easily done with leather gloves and a hot air gun (paint stripper). PVC gets soft & pliable at fairly reasonable temps.
May 14, 2010. 12:54 AMpanks says:
Outstanding!! thanks so much for sharing your idea. I need to build a retaining wall from earthbags and I just love this :)
5 stars for you!
Mar 25, 2010. 4:23 PMtemper says:
Absolutely excellent choice of background music!
Mar 17, 2010. 8:31 PMakgooseman says:
Very nice. One could add a 1x4 or 1x6 hopper on top to help catch the shoveled sand and drop it into the tubes instead of shooting off the side.
Mar 22, 2010. 7:59 AMbillrehm says:
What about using a sheet of heavy pvc plastic instead of plywood? The only kind I can think of readily available is those "roll up" plastic toboggans. That would make the unit lighter and you might be able to "form" it with hot water.
I'm offering this as a possible minor tweak to an already brilliant idea.
Mar 25, 2010. 2:41 PMalpratt says:
You could perhaps use one of the plastic floor mats like those used under chairs in places which have rugs. (Like I have in my home office.) Office Max or Office Depot will carry them. They're not real cheap, but you could get several top plates out of one mat.
Mar 25, 2010. 5:57 AMlaycockr says:
You could just drill 2 holes in the frame and use some rope to form a handle..
This would not add anything else to width of the project.
Mar 19, 2010. 7:26 AMArano says:
i think it may be usefull to add handles to the frame for easier/quicker turning upside down
Mar 22, 2010. 7:56 AMbillrehm says:
Couldn't you just use a drill and form a handle in the 2x4 frame?
Mar 21, 2010. 7:30 AMtyknappy says:
Nice idea, I wish I had that when I was fighting the flood last year, I used the ones made out of cones and they are hard on the back
I also live in Fargo : )
Mar 19, 2010. 5:47 PMYour Average Guy says:
This would be great in a war actually, i mean, if you need quick cover. I bet it'd save loads of time. So, where do you get the bags exactly? I can't seem to find any (probably not looking hard enough)
Mar 19, 2010. 11:18 AMJudith756 says:
I wish the state of Louisiana officials would see this.  Since many times every year sand bags are filled over and over.  Great idea and you should probably patent it before some "yahoo" does and makes millions.  Thanks for the design.
Mar 17, 2010. 10:09 AMnetstorm2k10 says:
Well done! This is needed right now, nationwide.  Good Job friend.
Mar 19, 2010. 6:36 AMnoname420 says:
Sorry im being a prick, but I live Washington state, and almost every year we get floods and such. But oddly enough while most of the country is having flood problems, our rivers are scary shallow. And its only march im pretty worried about the summer because we got little to no snow in our mountain area.
Mar 18, 2010. 2:47 PMthepelton says:
I live in a high part of Colorado Springs, so it would be a major national disaster before that area flooded, but for someone in a low area next to a river, this sounds like a must have.
Mar 17, 2010. 5:57 PMluvit says:
 thanks!! i surrounded my house with this. just inside the razor wire fence.
Mar 17, 2010. 9:33 AMchaosrob says:
I must say, very good idead. You see, I am a techie and I am (just now) training myself to NOT look for the most difficult way possible to do things. There is something to say about 'quick and dirty' (pun intended). :-)
Mar 17, 2010. 7:46 AMToniRose says:
Awesome. And great crew you've got there!
Mar 16, 2010. 10:04 PMl8nite says:
Looks like a great tool. Ive often wondered why when it starts looking like flooding is coming the gov't doesn't commandeer all the plastic bags of fertilizer, mulch,rocks etc that so many stores sell. OK it would probably cost $$ but think of how ez it is to unload a truck full of ready filled bags
Mar 17, 2010. 5:40 AMsarahfish says:
Very cool. I wonder how you could get these/this technology out to developing countires, perhaps through d-lab @ MIT?  Seems like it could really help in major floods around the world.
http://d-lab.mit.edu/
Mar 16, 2010. 9:10 PMjustin.jackson says:
 egh, sandbags... bad memories. (Iraq)
Mar 16, 2010. 3:19 PMJohenix says:
I have seen photos of Traffic Cones (Witches' Hats to you Brits and Ausies) mounted between 2x4s for sandbag funnels.
Could someone come up with a sandbag filling machine, say a double decker rotary table where the sand goes on the top table and the bags rest on the lower table and one person puts a bag on the snout, the table revolves, the bag fills, and another person removes the bag for a third person to close?
Timely as Fargo, ND is starting to flood.
Mar 16, 2010. 8:05 AMCaseyCase says:
 Quite a great idea but isn't child slave labor against the law? (Chuckling)
Mar 16, 2010. 6:55 AMroadieflip says:
Awesome idea. I am surprised nobody has thought of this before.
A great thing to make if you live in an area prone to flooding.(which seems to be happening more and more these days)
5 GOLD stars. Possibly one of the most useful instructables I have seen recently.
Mar 16, 2010. 1:25 AMJayefuu says:
This is fantastic! Saves so much time and pain :D You should put the video in the first step in my opinion, a lot of people don't have the attention span to get to the last step if they don't understand immediately. :D
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
7
Author:RiverOakRanch
