3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Filling Sandbags the Easy way, with Sandbag Tubes
Step 2Assemble your Tubes
Assemble your Tubes
First, get out the saw-
  - Cut  the sewer pipe into 6 sections (each 19-7/8" long)
  - Cut the lumber into the following sections
        - (3) 2' 2"
        - (2) 1' 5-1/16"
        - (4) 6- 5/16"
Now, assemble the wood as shown in the diagram below, using the 3" screws (or nails) to hold the boards together.
Once you have your frame, you can see how you will slide the tubes into each hole.  You will need to put the 1-5/8 screws through the tube and into the sides where it touches the boards on all four sides. There should be two screws at each spot.  First, take your drill and pre-drill the 8 holes on each tube; one at 1" from the top and one at 2.5" from the top every 90 degrees. Now put the tube in the frame and put screws in each hole. The easiest way is with a right angle drill.
When all 6 tubes are screwed on, the tubes are usable. At this point, you can put on the optional top. The advantage of putting on the top is that it will prevent sand from falling down next to the tubes and pushing the bags down. If you are going to put the top on, cut the top to fit over the frame. Screw the top onto the frame boards. Now drill a hole and then using either a router or a hand jigsaw, cut the holes out for each tube.
2 comments
Mar 17, 2010. 8:31 PMakgooseman says:
Very nice. One could add a 1x4 or 1x6 hopper on top to help catch the shoveled sand and drop it into the tubes instead of shooting off the side.
Mar 22, 2010. 7:59 AMbillrehm says:
What about using a sheet of heavy pvc plastic instead of plywood? The only kind I can think of readily available is those "roll up" plastic toboggans. That would make the unit lighter and you might be able to "form" it with hot water.
I'm offering this as a possible minor tweak to an already brilliant idea.
Mar 25, 2010. 2:41 PMalpratt says:
You could perhaps use one of the plastic floor mats like those used under chairs in places which have rugs. (Like I have in my home office.) Office Max or Office Depot will carry them. They're not real cheap, but you could get several top plates out of one mat.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
7
Author:RiverOakRanch
