3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Filling Sandbags the Easy way, with Sandbag Tubes
Step 3Using the Tubes
Using the Tubes
 To use the tubes, you just need to flip it over and slide a bag on each tube. Roll it back upright and start shoveling to fill the bags. By design it will fill each bag to about 35lbs. Once you have filled all 6 tubes, pick it straight up and the sand will slide out of the tubes into the bags. Then you will have 6 perfectly filled sandbags.
As you could see from the video in the intro, it was easy for two young kids with small shovels to fill sandbags, averaging about 15 seconds a bag. This is at a work pace that almost anyone can do.
So there you have it, an hour of prepwork can save countless hours of bagging.
3 comments
May 25, 2010. 12:02 PMdigimancer says:
 Add a lip to the outside edge.
Jan 24, 2011. 2:06 PMBroom says:
... which is easily done with leather gloves and a hot air gun (paint stripper). PVC gets soft & pliable at fairly reasonable temps.
Mar 25, 2010. 5:57 AMlaycockr says:
You could just drill 2 holes in the frame and use some rope to form a handle..
This would not add anything else to width of the project.
Mar 19, 2010. 7:26 AMArano says:
i think it may be usefull to add handles to the frame for easier/quicker turning upside down
Mar 22, 2010. 7:56 AMbillrehm says:
Couldn't you just use a drill and form a handle in the 2x4 frame?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
7
Author:RiverOakRanch
