This Instructable shows you how to make a Zat Gun from Stargate. The only thing is that this won't stun anybody, and it doesn't fire that neat blue lightning bolt. Instead it works by igniting a flammable gas in an enclosed space. This enclosed space is the inside of a film canister.
DISCLAIMER:
If you hurt anything or blow your eye out it isn't my fault.
Step 1: Get Your Stuff
Here is a list of the materials you need:
  • Piezoelectric quartz igniter. I will show you how to get this from a cheep lighter.
  • PVC. I used a 1/2 inch diameter chunk about 20 inches long.
  • PVC end cap. This is for the end mount.
  • 1/2 inch PVC end cap. This is for the but end of the 1/2 inch pipe.
  • Speaker wire. I used about 18 inches of solid speaker wire.
  • Electricians tape. You need lots, the more the merrier.
  • Solder.
  • Shrink Tubing.
  • Several film canisters and one film canister lid.
  • Sand. For bending the PVC.
Here are the tools you will need:
  • Soldering Iron.
  • Hot Air Gun. For the shrink tubing, matches will work also.
  • Gas Stove or Bunsen Burner. For bending the PVC.
  • Screwdriver. For gutting the lighter.
  • Wire Strippers/Cutters.
  • Hack Saw. For cutting PVC
  • Drill. For drilling out the larger PVC end cap.
  • Epoxy. For gluing on the larger end cap.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
