Please Rate and Leave Comments.
Thank-you!!!
Remove these ads by
Signing UpStep 1Aim and Materials
Materials:
Dried Dirt (from the ground)
Bleach
x2 See Through Glasses
Water From The Tap
Spoon
x2 Filter paper
Funnel
http://rvbasics.com/techtips/sanitizing-your-rv-fresh-water-system.html
from another site
http://www.i4at.org/surv/bleach.htm
Whether you use Clorox Bleach in an emergency or for everyday chores, it's always an environmentally sound choice. After its work is done, Clorox Bleach breaks down to little more than salt and water, which is good news anytime.
*Ratio of Clorox Bleach to Water for Purification
2 drops of Regular Clorox Bleach per quart of water
8 drops of Regular Clorox Bleach per gallon of water
1/2 teaspoon Regular Clorox Bleach per five gallons of water
If water is cloudy, double the recommended dosages of Clorox Bleach.
(Only use Regular Clorox Bleach (not Fresh Scent or Lemon Fresh). To insure that Clorox Bleach is at its full strength, replace your storage bottle every three months.)
**(Clorox Bleach Sanitizing Solution)
Mix 1 tablespoon Regular Clorox Bleach with one gallon of water. Always wash and rinse items first, then let each item soak in Clorox Bleach Sanitizing Solution for 2 minutes. Drain and air dry.
PUREX and CLOROX bleach used to have water purification directions on the (glass) bottles... years ago. It was just a couple/few drops per gallon. It would kill germs, bacteria, etc.
Bleach (sodium hypochlorite) is a very common, easy to find product and much safer than Hydrochloric Acit (HCl)
I have a hole in my sidewalk where a LITTLE BIT of diluted Muriatic acid spilled. I'd immediatly poured a baking soda solution on it to neutralize it.... Dangerous, corrosive stuff, it is...
I'm not necessarily recommending the bleach, but if it were an emergency situation, I'd do it in a heartbeat...
You're instructable would be a lot better and interesting if it had photos, it's just pretty boring just having to read everything. And you might have made the instructable but not followed it.
