Outdoor Pallet Cabinet by jbberlo22
First you must obtain 3-5 pallets. These can be found outside hardware stores, industrial areas, and even grocery stores. You must also purchase two hinges for around 5 to 10 dollars
Step 1: Disassembling the pallets
Next you must take apart the pallets. Each one takes around 30-45 minutes to disassemble. The most important tool for disassemble is a claw hammer but others can be used. Be careful of weak wood because some can break easily. Make a pile of wood once you have taken them apart.
blkhawk says: Apr 30, 2012. 3:56 AM
I would have trued the planks on a table saw before I build this project. It looks flimsy and unsafe. If you plan to make this into an outside cabinet, how do you plan to anchor this to a wall?
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
