Finding your bra size isn't hard - it just requires a measuring tape and a little simple math.
Note: There are (kind of goofy) illustrations of boobs in the following steps; if they offend you, I'm sorry in advance. If it offends you that they're just drawings (and not real boobs), sorry about that too.
Remove these ads by
Signing UpStep 1Measuring the Band Size
Round all fractional measurements to the nearest whole number. If the number you get is even, add 4 inches; if it's odd, add 5 inches - jot that number down, it's your band size (the 34 portion of 34D, etc.)
When measuring, it may help to have someone else measure you to ensure that the tape is not twisted, and that it's parallel to the floor around the back.
Ultimately, you only know what bra size you are when you try on a bra and it lines up and fits perfectly. But this is a great system to know which end of the clothing rack you should start looking.
Also, your bra sizes stop halfway up the scale - it's possible to buy bras off the rack that go to J cup. It has nothing to do with being fat, and everything to do with how much breast material is present.
According to the above measurements, which I always followed, I'm a 40DD, because DD was as high as my cup projection ever allowed, and I suffered through 20 or so years of discomfort and pain as a result. 5 years ago I was hired on at a lingerie shop, and I was immediately fitted by the owner as a 38I.
40DD and 38I are not near each other, but the former is what I got from a measuring tape, and the latter is what I got from an experienced fitter who didn't touch a tape. :D
I have since lost about 45lbs, and I am down to a 36H, which is another matter... women think they're losing cup size when they lose weight, when most of the sagging, bagging, and unhappiness comes from swimming around in a HUGE band size. Your band SHOULD be tight - it's where your support comes from. Bra straps are for shaping - if you have to tighten them to get lift, you need a tighter band and a larger cup, probably.
Anywho, just thought I would mention that. Sizes over F are really common - stopping at triple-D is like not showing women's shoe sizes over an 8.
Good luck and thank you for the info either way, its good to see people who want to inform others!! :)
I'm afraid I'm not sure what you mean "doesn't work" or why you would need to be wearing the right size bra to fit yourself using a measuring tape. As noted here, you should measure while not wearing a bra (unless the shape of your breasts would make that difficult - in which case they could be supported with your hands while someone helps you measure, or with a bra that lifts them and is as well-fitted as possible). Step 3 here also provides some additional information about signs that a bra doesn't fit well (straps digging in, the center gaping away from the chest, etc.).
Regarding larger sizes, I am personally well aware of the scale for sizing going larger than indicated here (before I had surgery I was a 34FFF). I only made the chart/list go as far as DDD because I could not fit more information on it. I should have indicate that the "pattern" of sizing follows the same way - adding one inch to the difference between the measurements means adding a letter size.
As noted in the tips in step 3, gaining or losing weight is for sure a reason to re-measure yourself. That said, the band of your bra should be snug and it should fit against your skin well/comfortably, but should not be "tight" - it should not dig into the skin or feel like it is digging in. Also, it should not pull up across your back, if it does, the shoulder straps of the bra are likely too tight and the band may be too large.
Thanks again for all your comments!
Good Ible. I just did the math, and mine is a "AAAAA" by those standards. The measurements are the same. This of course is not surprising, as I'm male.
That also reminds me of an old joke: How do you make 2 lbs of fat look beautiful? Put a nipple on it. :D
