Finding a local bouldering spot.
 by randofo
Step 4: SAFETY! SAFETY! SAFETY!
Alright, once it has been determined that the boulder is climbable (the rock is strong and you can lift yourself off the ground), you are going to want to determine what would happen if you fell off the boulder.
Look at the ground around the base of the boulder. Are there a lot of large rocks around that cannot be moved? If so, it is most likely too dangerous to climb there even if you have a safety pad to cover them. Is the boulder at the top of a steep incline? Will you roll painfully down a hill if you fall off or twist your ankle? If there is loose gravel around the base of the boulder? You can twist your ankle on that too. Is there anywhere for your spotter to stand safely and support your fall?
*Remember: always boulder with a "spotter"--a person that doesn't catch you, but rather stands behind you and supports your fall so you don't hit the ground head first.
The point being that if the ground is uneven or covered in major hazards that cannot be removed from the area, you probably don't want to climb there.
zip0nada says: Nov 19, 2009. 6:51 PM
Personally, these are the sort of things I think about as soon as I see a potential bouldering spot. Step two, rather than step four, but I suppose it doesn't matter that much as long as you don't get too overzealous testing the rock.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
