The instructable is to make a 3-D hollow-form pendant for a necklace. We make the hollow form by coating a Completely Dry organic armature (Popcorn, in this example) with 8-12 layers of Precious Metal Clay (PMC) Paste.
When fired, the popcorn will burn away, leaving only the pure (99.9%) silver from the PMC in the shape of your popcorn kernel!
Required Stuff:
Jar of PMC3 (Precious Metal Clay) paste.
1 inch piece of Fine Silver wire (dead-soft).
Popped Popcorn.
Victory Wax (or cheese wax).
Hot plate.
Shallow pan for water.
Metal measuring cup for melting wax.
Small Paintbrush.
Bamboo skewers.
Styrofoam.
A craft or ceramic kiln of some kind.
Small, smooth jawed pliers.
Pencil.
Wire cutter or scissors.
Brass brush for polishing.
A necklace, piece of ribbon, or leather cord.
...all will become clear...
Remove these ads by
Signing UpStep 1What is this Magic "PMC" Stuff?
This product became known as Precious Metal Clay (PMC).
After drying, the PMC is heated to the fusing temperature of the constituent metal. During this heating, the binder burns away, and the metal particles sinter together into solid metal.
We will be using a form of this product which is pre-prepared to a paste-like consistency.
Basic PMC Working Tips:
Its all about the moisture, PMC can dry out very quickly.
1) Plan ahead (have your tools at hand) before you open your jar of paste.
2 ) Water can be used used to moisten the clay and smooth the surface of your pendant.
3) Dried out PMC can be reconstituted with water and reused.
I really like the idea of this piece. You did a great job on it. I would like to ask you something. I have a dried lizard. We found it in the ice-melting salt that you put on sidewalks. Do you think it could be turned into a medallion with this process? Will I need to wax it down?
Thanks in advance,
Adam.
You were right in skipping the wax step, that's so the popcorn keeps its shape. It sort of "deflates" from the water in the paste. It wouldn't be needed for your origami creation.
Since you already have origami skills, you might want to try "PMC Sheet". A Google search on that will turn up many sites, but here's an typical one: http://www.dickblick.com/zz305/22/ . The sheets are kind of small, but you could create your crane or other origami directly without all the layering steps.
gets my +
and a VAMPIRE award
We'll be using the clay you mention in our next Instructable: "5 Minute Earrings", currently in production!
The jar of paste I used is currently about $25US. I used about 6 gms of paste, so the PMC for this project cost roughly $10US. That's really good for a one-of-a-kind piece of jewelry!
Looking forward to your next instructable.
I did a quick currency conversion, though, the prices I pay are about the same as you!
