Having a light attached to one's finger can be extremely advantageous when working in tight spaces.
This instructable will demonstrate how to make an inexpensive finger light using commonly available parts.
Parts List:
Step 1: Remove the clip
Remove the clip from the LED light.
Step 2: Outline
Trace the outline of the clip on the neoprene mouse pad.
Step 3: Cut
Cut the shape out of the neoprene mouse pad.
Step 4: Contact Cement
Apply contact cement to both the bottom of the clip and the fabric side of the neoprene mouse pad.
Step 5: Squeeze
After the contact cement is dry, squeeze the neoprene on to the clip.
Step 6: Strap
Put the hook-and-loop cable wrap between the clip and the LED light. Make sure the fuzzy side faces out; the hook side will snag on clothing and other items if it faces out.
Reattach the clip to the LED light.
Step 7: Finger
Wrap the strap around the finger and the light is mounted.
Leave the cable wrap long if the light is to be attached to various other objects. Otherwise, cut to length.
