3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Finger Top on a Lathe
This instructable will show you how to make a top that spins on the tip of your finger. I used a shopsmith 10er that I got off craiglist but this can be done with any lathe that has either a faceplate or a chuck. This is an easy rewarding project that can be accomplished in under half an hour.
You can see a video of this finger top here redirectingat.com/
I'm no expert turner but hopefully I show enough setup and a couple tricks to make setup and turning easier. This is one of my first projects and I have no training on a lathe so feel free to make corrections to any of my steps.
Step 1Tools and Materials
Tools and Materials
The main and most obvious tool is the lathe, you'll also need a couple different chisels for the lathe, a faceplate for the lathe, a hot glue gun with glue sticks, and a saw.
As far as wood goes you will need a small piece of a close grained hardwood. I am no expert in wood types so I just go around picking up different types and playing with them until I find one I like. I dont know what type I used it was just a 2" log I found on the ground. As chipf mentioned in a comment make sure the wood isnt green, meaning its dried for an extended period. Green wood will shrink and warp as it drys making something that was circular when you turned it change shape over time.
*You'll also need a scrap piece of larger diameter wood atleast the size of your faceplate. You screw your faceplate onto this and glue your piece to the other side.
*note
If you have a chuck then you dont need to do this, you can just chuck your piece of wood.
9 comments
Apr 10, 2010. 4:56 AMchipf says:
Be careful using logs especially if they are green. When they dry the piece will more than likely distort and many times crack. Also I have been turning for 20 some odd years. Use double stick tape instead of hot glue it is a little more safer and reliable. Good instructable .
Apr 10, 2010. 11:00 PMsssssbooom says:
sense you are parting it off anyways and you are gluing to a scrap piece of wood I would just use regular wood glue. Double faced tape for turning can be kind of expensive (or maybe I am cheap).
Apr 12, 2010. 8:08 AMlasersage says:
The instructable was pretty good. I like the spinning top too, never seen a finger tip one before.
I don't understand why you'd glue anything though. Why don't you just screw into the lump you're intending to turn, especially as you part it off anyway?
Apr 11, 2010. 9:05 AMchipf says:
1 Roll has lasted me for 5 years. It cost me $4 to me that is a good investment.
Apr 11, 2010. 9:44 PMsssssbooom says:
Hmmm, at my local wood craft it is $20.99 for double faced turning tape 1" x 36 yards. http://www.woodcraft.com/Product/2000390/3903/Double-Faced-Tape--1-x-36-yds.aspx
What kind of tape are you using? I might be interested in buying some.
Apr 11, 2010. 12:26 PMbuckmcf says:
Great work, I love the fact you used such a great tool as a Shop Smith 10ER, I purchased one a few years ago and love every minute that I use it.
Apr 10, 2010. 12:20 AMTape-structable says:
Looks fun! I've never seen one of these until this instructable.
Looks professional.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
21
Author:Jor2daje
