This instructable will show you how to create a deck plate and sides for your Harbor Freight utility trailer frame. While this example is for the model/item no. 42708, the techniques may be applied to all models, with appropriate dimensional revisions.
Materials needed:
1/4" Diamond plate x 41" x 48"
(12) 1" x 4" x 8' pressure treated boards
(40) 1/4" x 2" galvanized carriage bolts
(8) 1/4" x 1" galvanized lag screws
(8) 1/4" x 1-1/2" galvanized lag screws
(56) 1/4" galvanized washers
(48) 1/4" galvanized nuts
Tools/equipment needed:
Miter saw
Drill press
Drill
Socket wrench
Large bar clamp
C-clamps
Carpenter square
Remove these ads by
Signing UpStep 1: Deck
Attach the deck plate using the 6 stock hex head bolts along the frame rails. You may also add additional bolts in the center of the end rails and center cross member.
deck_plate.dxf19 KB
Visit Our Store »
Go Pro Today »
For those that question the validity of these techniques I would like to point out that your "typical Aluminum is softer than a lot of hard woods that are cut/shaped with these same tools. Remember to follow ALL shop safety practices when using power tools. Especially eyes and ears (Incredibly loud and lots of chips.)
I've used my miter saw to cut aluminum and copper tubing on numerous occasions.
The first time, I was thinking that I was just saving time and thought at the price of the blade... "what the heck". The blade just didn't seem to care.
The carbide blade works ever so nicely.
I would have made the rear gate latch in place with butterfly latches or draw latch. Hinge the bottom and reinforce the timbers from the backside. Instant foldown ramp. Just makes it more practical for moving lawn mowers, carts, anything on wheels.
Nice build! Lets see a folding tailgate now!
However, since each side is only held by 2 lag bolts at the bottom, and 2 at the top, you can take off any or all sides with a socket wrench in about a minute.
It worked perfectly.
I went with 2X12 oak flooring(no frame wracking now) and eight 2X4 X4 pine stakes with a 1/2X4 pine half way up and another along the top.Then stapled plastic garden fencing all the way around for the 'walls'. Rear gate was easy too.Cut the 2X4's at 45 degree angle about three inches up from floor then use six inch strap hinges to put them back together.Makes a nice load ramp for lawnmowers etc.....
First of all, I noticed in Step 3 you show the Lag Bolts as being put in with the button head on the outside. While that makes for a pretty appearance, when I built mine I put them on the inside to prevent me from scraping up the back of my hands, arms, and stuff in the trailer on the end of the bolt.
Second, my trailer has 3 hasps at each corner with a long rod running down through all of them so they are easily removable. It allows me to take off a side or end for loading but still keeps the rest of the walls intact. The hinge base is on the side and the loop is on the end so that the hasp wraps around the corner and holds everything in place. Since I fold mine up and store it in a corner of the garage when not in use, it is very convenient. It also allows me to take the sides off without the use of tools when I need to.
http://www.lowes.com/pd_201711-152-LBR-201711_0__?productId=3020106&N=0&catalogId=10051&langId=-1
for example in the link provided 1"x4"X8' pt was $3.97 for my location.
I paid $4.97 for 5/4"x6"x12' pt decking.
