Step 3The Leg Wire's Connected to the Hip Wire
After you strip each end, roll the bare wires in your fingers until the strands of wire are twisted around each other. This will keep loose strands from one wire from accidentally making contact with another wire and ruining your day.
Use your wire cutters to open the housing on Stumpy's USB connector, so that you can get at the four pins inside the end. A little like opening a can of beans. Mmm, shiny conductive beans.
Now we're going to test continuity so we can find out which pins inside the USB connector go with each color wire inside the cable. Put your multimeter into resistance mode (ohms) or continuity mode, and clip or press Stumpy's wires to either lead. With the other lead, touch each pin until you see a low resistance reading or the continuity alarm sounds. Write down which color went with which pin. You can start numbering them from the top, bottom, left, or right. My list looked like this when I was done:
Red - pin 1
White - pin 2
Green - pin 3
Black - pin 4
And what about that big mess of stranded wire? Test it against the connector's housing -- bingo!
Hold Stumpy's connector up to the USB socket we found in step 1 as if you were going to plug it in. Note how your numbering scheme lines up with the circuitboard pins leading to the USB port.
comment
Add Comment
Add Comment
