Fire Alarm System
Introduction: Fire Alarm System
Note: My English language is not good enough. I can read and understand but I do not speak much.
Sorry ;)
Step 1: Materials for Project
We will do a fire alarm system in our project. So let's start!
Here is what you need to make a fire alarm system:
  • Arduino ( I had the Arduino Uno)
  • lm35 Temperature Sensor
  • 3 Leds (Different Colors)
  • Buzzer
  • Cables (Jumper Cables)
  • USB Cable for connection to PC
You just need this materials. And we're ready for the next step; connection.
Step 2: How Can We Establish a Connection?
First of all, we keep together all this materials. And we are ready to begin.
  • led red; pin 2
  • led yellow; pin 3
  • led green; pin 4
  • Buzzers inputs brought an input plus pole and another input negative pole.
  • The sensor is also connected in a similar manner. But the middle sensor input brought pin A0 or Anolog 0.
And we established a connection with all this materials. Next step is Fire Alarm System Projects Code.
note for this code; "void_t" fonction is for buzzers working.
led_k=red, led_s=yellow, led_y=green
int led_k = 2;
int led_s = 3; int led_y = 4;
void setup() { Serial.begin(9600); pinMode (led_y, OUTPUT); pinMode (led_s, OUTPUT); pinMode (led_k, OUTPUT); } void loop() { float temp = (5.0 * analogRead(A0) * 100.0) / 1024; if(temp>30) { digitalWrite (led_y, LOW); digitalWrite (led_k, HIGH); digitalWrite (led_s, LOW); t(); } else { if(temp>26) { digitalWrite (led_y, LOW); digitalWrite (led_k, LOW); digitalWrite (led_s, HIGH); t1(); } if(temp<26); { digitalWrite (led_y, HIGH); digitalWrite (led_k, LOW); digitalWrite (led_s, LOW); noTone(7); } Serial.print ("Temperature Value: ");
Serial.print (temp); delay(500); } } void t() { tone(7, 494, 500); delay(1000); } void t1() { tone(7, 494, 500); delay(2000); }
    • Epilog Challenge 9
      Epilog Challenge 9
    • Paper Contest 2018
      Paper Contest 2018
    • Pocket-Sized Contest
    This is an interesting project. Thank you for sharing!
    thanks for comment. I also upragede this project with arduino robot. coming soon!
    Hey I tried to do this project but for some reason it isn't working.....I followed the circuit diagram n put it together properly (I Checked 5 times). I also copied your code but it aint working. Only the green led is glowing all the time.
    A fire alarm system is responsible for regulating an entire system of fire alarm modules within a building and can operate through mechanical or electronic activation.
