Fire Balloon
49,512
684
50
Posted in PlayToys
Introduction: Fire Balloon
This will give you step by step instructions to make a fire balloon or sky lantern.
SAFETY PRECAUTIONS: This project involves highly flammable materials. Children should only make this if accompanied by an adult. Don’t use the fire balloon in dry areas or in areas where a fire could start. The best place to use a fire balloon is over a large body of water.
Step 1: Materials
- Five pieces of large tissue paper or waxed rice paper
- Scotch Tape or Masking tape
- Rubbing alcohol or lighter fluid
- Kitchen sponge or similar absorbable material
- Scissors
- Wire
- Lighter or matches
Total cost: $5 to $15
Gather the materials to make the fire balloon. You will need large sheets of tissue paper or large sheets of waxed rice paper. Tissue paper can be bought at most department stores or grocery stores. The paper needs to be thin enough for the balloon to lift off the ground. Copy paper and most paper bags are too heavy for the heated air to lift them off the ground. You will need scotch tape or masking tape to tape the pieces of paper together.
For the fire, a small sponge soaked in rubbing alcohol is used. Many other things can be used besides the sponge. The material just needs to be able to absorb the rubbing alcohol and light enough to not weigh the balloon down. With this balloon, a standard kitchen sponge and 91% isopropyl alcohol is used. Lightweight wire can be used to connect the sponge to the paper balloon. String can’t be used to connect the sponge because it will catch fire once the sponge is lit. It’s easiest to light the sponge with a grill lighter if you are by yourself. If you are with multiple people, you can light the sponge with a normal lighter or matches. Someone can hold the balloon up while you light the sponge from underneath. If you are by yourself, it’s easiest to set the sponge on the ground and light it with a grill lighter while holding the balloon up with the other hand.
Step 2: Taping the Sheets of Paper Together
Lay four pieces of tissue paper out next to each other. The longer sides of the sheets should be next to each other. Overlap the sides so the pieces of paper can be taped together. About a half-inch or a centimeter is enough. Use scotch or masking tape to tape the pieces together. The tape needs to run the whole length of the pieces of paper so that the heat can’t escape the balloon after the sponge is lit. Check along the tape to make sure there are no gaps between the two pieces. The four pieces should just look like one large piece of tissue paper now.
Step 3: Making the Balloon Into a Cylinder
Take one short end of the large taped together sheet and fold it towards the other short end. Tape the two short ends together so the large sheet resembles a hollow cylinder. Once again, the tape must run the hold length of the two edges. It’s important to remember that the heat must be kept inside the balloon, so no gaps or holes.
Step 4: Putting a Top on the Balloon
Next, a top must be put on the hollow cylinder to trap the heat. Another piece of tissue paper can be used. Fold the cylinder along the taped portions to form more of a box shape with the cylinder. It might naturally form a box shape already. Set the balloon on the ground with one side on the ground and one side facing up toward you. Take the last piece of tissue paper and place the short end about 4 to 6 inches down from the top. Leave the longer portion up above the balloon. It will be taped to the other side. Run a piece of tape along the whole edge of the paper.
Flip the balloon over and do the same thing to the opposite side.
Step 5: Completing the Top
Turn the balloon on its other sides and tape all the edges closed. The balloon should now only have one open side. Check over the whole balloon to see if there are any gaps or holes where hot air could escape.St
Step 6: Making the Fire Source
The kitchen sponge should be cut to a smaller piece so that it can fit in the balloon and so it won’t be too heavy when soaked with alcohol or lighter fluid. Half-inch to one inch sides (or about 3 centimeters) will work fine.
You will use two pieces of wire to connect the sponge to the balloon. Beading wire is used here because it is lightweight and inexpensive. The two pieces need to be about one inch or 3 centimeters longer than the width of the whole of the bag. The beading wire can be cut with scissors, which is also helpful. You can find it in most craft sections at department stores.
The wire should be pushed through the sponge long ways on each side. The portion of the sponge with most surface area will be facing upward toward the top of the balloon once it is connected. Position the wire so there is an equal portion on each side of the sponge.
Tape each end of the wire to the balloon at the edges of the opening. The sponge should be positioned in the middle of the opening so the tissue paper doesn’t start on fire.
Step 7: Getting Ready to Light the Fire
Soak the sponge in alcohol or lighter fluid being careful not to get any alcohol on the tissue paper. This step is easiest to do if you are working with another person. One person can hold up the balloon while the other soaks the sponge.
Step 8: Lighting the Sponge and Letting the Balloon Go
Finally, when lighting the sponge, it’s easiest to light the sponge using two people, but it can be done with one person if you’re careful. The balloon needs to be held up when the sponge is being lit so the paper won’t catch fire. If you’re by yourself, hold the balloon up with one hand while using a grill lighter to light the sponge with the other hand. Caution needs to be used when lighting the sponge. The whole balloon can catch fire very quickly if you’re not careful. Set the lit sponge on the ground in the middle of the opening of the balloon. Set the balloon over the fire so hot air starts to fill the balloon. Wait a few minutes and your balloon will take off.
  • Microcontroller Contest
  • Space Challenge
    Space Challenge
  • Science of Cooking
    Science of Cooking
50 Comments
These set fire to hundreds of buildings and fields each year. The safety precaution should be not to do it at all. You are obviously not a responsible adult if you are oblivious to the dangerous and costly hazard you are causing.
Well, you can launch them in the middle of an ocean or maybe a sea or something. That wouldn't set fire to anything.
Launching lanterns over water is still a major hazard to wildlife and is illegal in many places.
um,,,, ACTUALLY,,, wildlife doesn't exist sweetie :)) so don't have to worry about your poor little 'animals' setting on fire now do we ;)
bye boo :*
Obviously you have no idea what you are talking about. There's a 3000 years history of the sky lantern and there have never been a serious accident unless stupidity sets in. Once the sky lantern fly up, it does not come down even long after the flame dies down. properly done sky lantern are safe and environmentally green.
You can buy them for $2.50 each here: http://vancouver.craigslist.ca/pml/hsh/4713256335.html
Maxhuey, you are so wrong. We sent one of the Groupon ones up and it almost caught the dried leaves of a tree up in flames. That is personal experience. We were in a large clearing about 1/2 acre that was surrounded by trees. We had no wind on the ground but when it got 1/2 way up the height of the trees it went right into the branches and kept burning. We attribute not having a fire to the ones sold by Groupon have a flame retardant paper. 3000 years and not a serious accident, any proof to that or did you just pull that one out of your.... and have a nice day.
FYI: https://www.youtube.com/watch?v=1vPRTgEMMOw
Common sense dictates that you do not fly this in areas of trees, airports etc. I guess you have not use C/S... :-)
No need proof, history is there for you to see (Google is your friend: Kong Ming lantern was invented some 3000 years ago in China. Every year since, there have been celebrations all over Asia flying these by the hundreds and sometimes thousands. If only you have traveled to Pingxi, Thailand, Vietnam, etc and other parts of Asia. you would not have ask..Its Common knowledge...
Why not attach fine monofiliment to it so you can control it so it doesn't become a hazard? Just saying...
Good idea, but the mono can and does get close enough to the fire pad to melt and release the balloon (it happened to me a few times launching over a lake and I had to paddle to the landing site and put out the fire pad).
I just spray the tissue paper with homemade flame retardant spray, allow to dry between 3-4 layers of spray... For a make-it yourself fire retardant mixture, mix 7 oz. Borax, 3 oz. boric acid, and 2 qts. warm water. Stir to dissolve completely. put in a spray bottle.. wha... laa...
http://wildfiretoday.com/2014/06/19/national-park-service-discourages-the-use-of-fire-balloons/ell, very cool. Kites with LED would be safe, maybe more fun. Free floating balloon may not be legal in your state or country. This article names the fire ballon outlawed locations for when it was written:
Cool instructable. I will definitely be trying this with my kids even though they are both grown. They still like to try stuff with me. What I find sad is that so many people read these and then try to pick them apart and down every thing about them. Someone even mentioned the possibility of wildlife getting caught in the wire. WTF?? I really don't think a probably no more than a 12 inch piece of wire is going to cause any animal any trouble. Otherwise, that animal might not be able to run out in front of someones vehicle and get into trouble like that. Come on people!! Take these for what they are. Just good clean fun for people that aren't paranoid about everything going wrong.
Ay caramba! Any idea of the damage done to dumb animals who get entangled in pieces of stray wire from these things? Here is a nice litany of the troubles they have caused in the UK: http://www.theguardian.com/uk-news/2014/aug/20/sky-lanterns-paper-chinese-new-guidance-warnings
As for the dry corn field on the photo that you are about to set fire to, I hope you are on good terms with the farmer.
WE DID THIS 40 YEARS AGO. HOWEVER, BACK THEN WE WERE NOT AS "GREEN" AS WE ARE NOW. WE USED LITTLE CAKE CANDLES AND A BAG FROM THE DRY CLEANERS. AWESOM! NOT VERY RESPONSIBLE FOR SURE. HERE IN THE SILICON VALLEY, IT IS FAR TOO DRY SO, DON'T DO IT PLEASE.
beautiful and dangerous.
the dangerous:
the beautiful:
Hmm, could an alternate heat source could be used? Perhaps hand warmer pads, wonder if they are light enough? Or heat up the air with a heat gun, then release the balloon.
This is the first Instructable that should be taken down.
Think about it: Let's light a fire and then let the wind blow it away to God knows where. They are banned in many areas for this reason.
Just plain not thinking.
oh come on. Like the guy said, don't be a knucklehead and launch it next to a hayfield. Do it over water or something. There are way more instructsbles here that do worse.
Ha, Ha, Ha......."The best place to use a fire balloon is over a large body of water." ... or a nice dry corn field!
