Fire Bell Alarm Clock
Published
Introduction: Fire Bell Alarm Clock
About: I like making cool stuff!
There are many ways you could create your own fire bell alarm clock it all depends on what type of alarm clock you are going to use. On the alarm clock I chose there is an led LCD back light and It turns on for about 6 seconds when the alarm goes off so I used that to latch a relay. If you have any questions feel free to ask!
    • Creative Misuse Contest
    • Clocks Contest
      Clocks Contest
    • Oil Contest
      Oil Contest
    5 Discussions
    I'm sorry the schematic is wrong the side of the relay coil hooked up to the collector of the transistor should be hooked to the first poll on the relay not the 9v. I'm going to upload a new one today.
    I think the schematic should look something like this
    I am assuming that once the backlight turns on and the relay switches that the relay's one pole will keep power to the coil of the relay and the button breaks the loop to disable the bell. So the button will be a push-to-break button. In this case the schematic is not correct. If I missed the purpose of the push button and the schematic is indeed correct, there is a direct short from the 9v to gnd
    What is the sense of button in circuit ? Does it shortcut the 9V battery or what ?
