Introduction: Fire Cube (Fire Starter)
Hello world! Pure Carbon here and today I will be showing you how to build a small, long burning fire starter that I call the fire cube. Its essentially a cotton ball covered with petroleum jelly which is compressed as small as it can. Its great for lighting emergency fires and is small enough to fit into any survival kit. It can be quickly be made using common household items and will burn for about 15 minuets. So sit back, Relax, and enjoy!
Thank you for all your support, and tips to help me improve my Instructables. Without you guys I wouldn't be doing this right now, you can expect many more Instructables in the future so don't forget to follow me and/or favorite this Instructable. If you have any question or concerns then be sure to comment, or if you just want tell me how awesome this is, that's fine too! Here it is, hope you enjoy it and once again thank you.
Check me out on: YouTube: https://www.youtube.com/channel/UCp1Iy_qqZl-TBWrw...
Channel ad:
Facebook: https://www.facebook.com/Pure-Carbon-398550910296...
Twitter: https://twitter.com/Pure_Carbo
Also Support me on Patreon where contributors get early access to all the videos I make along with free PDF downloads of all my upcoming Instructables: https://www.patreon.com/PureCarbon?ty=h
Step 1: Required Materials
Here are the required materials to build this project:
- A cotton ball, your choice of size just keep in mind that a larger cotton ball will take up more space, but will burn longer and a smaller cotton ball will take up less space, but will burn for a shorter period of time.
- Petroleum Jelly
- A pair of scissors
- A 2" by 2" piece aluminum foil
Step 2: Add Petroleum Jelly
First take a small amount of Petroleum Jelly and rub it all over the cotton ball until it's completely saturated. The jelly will help it burn longer and will keep it small and compacted.
Step 3: Create the Cube
I always knew those days of working with Play Dough would come in handy someday. In this step you will need to resurrect those suppressed Play Dough skills that you had when you were a kid and compress the cotton ball down as much as possible. You will then need to mold it into a cube shape because I have found that this shape works best. The Petroleum Jelly will also help it hold its shape.
Step 4: Wrap It in Foil
Now take your 2" by 2" piece of foil and wrap it around the cotton cube. The foil will help keep it dry in damp conditions, however it only makes it water resistant and will not protect it if it's completely submerged in water.
Step 5: Add Matches (Optional)
While wrapping the foil around the cotton you can add some matches and a striker if you intend in adding this to a survival kit, or an emergency kit of some kind. This step is obviously optional, but It can be useful if you don't have anything to light the cotton with when the time comes.
Step 6: Marvel at Your Work
Now you are done and you can marvel at your work. To light it all you need to do is first remove it from the foil fluff up one side of the cube and light using your preferred fire starting method. Enjoy you silly humans!
Like I said earlier if you have any comments, questions, or concerns then leave them in the comment section down below and I will be more than happy to respond. If you like this then please be sure to subscribe to me here and to my YouTube channel for more awesome content like this. there is link on my page to it so be sure to check it out. Thank you for checking out my Instructable and be sure to favorite it, once again thank you.
