Fire Dragon
Introduction: Fire Dragon
This is dangerous!
Keep ready a fire-extinguisher!
Never use indoors!
Keep a distance from people, animals and everything!
Wear non-inflammable clothes!
Step 1: Preparing the Trigger
Bend a wire so that it fits onto a gas can (as seen in the picture)
Take a little piece of wood, drill two holes into it and glue (epoxy recommended) the wire in for a handle.
Step 2: Preparing the Dragon
Find an appropriate dragon and a small rubber tube (small enough to fit onto the nozzle of the gas can)
Insert the tube into a slightly bigger metal tube and glue into the mouth of the dragon.
(this is important to insure more accurate and safer targeting)
Fill the head with foam (maybe from an old mattress) and cut a hole large enough to insert the gas can into.
Step 3: Assemble All Together
Put a small washer on the nozzle
Put the trigger on
Put a spring ( from a ink pen) onto the tube (this must fit tightly)
Place the tube onto the nozzle securing it with the spring (this is an important safety measure)
Put the can upsite down inside the dragon.
Step 4: Have Fun
YouTube Video
Use a torch to ignite the gas or a long candle or a gas oven lighter.
A normal lighter is too short you will burn your hand!
This is my entry for the HALLOWEEN PROPS CONTEST 2015
If you like it, give it your vote, Thank you!!
    • Pocket-Sized Contest
    • Science of Cooking
      Science of Cooking
    • Pro Tips Challenge
      Pro Tips Challenge
    Very cool, I like this!
