Introduction: Fire Missiles Cigarette Lighter
Bored? Have a car?...Probably. This project is great for people who honk their horn too often; also, for people who like cool things.
Step 1: Materials/Tools
Materials:
- ABS Filament
- Red Nail Polish
- Cigarette lighter
Tools:
- 3d Printer
- Sand Paper
Step 2: Ddd Print
Use this file to 3d print the plastic component.
Step 3: Clean Up the Print
Start with something heavier duty, then move on to something of more detail. I started with a chisel, then moved to a razor, and finally sanded it.
Step 4: Paint
Using the red nail polish, fill the letters with nail polish. Then use something like a piece of paper to scrape off the excess. Let it harden for about half an hour. Then sand it again. Makes sure to use an air compressor to blow it while you sand it. Otherwise the abs dust will get in the letter grooves and make it look awful.
Step 5: Combine
The first time I put it together I was worried it would break. I ended up using a lot of force to attach the abs part to the cigarette lighter; however, it did not. I then proceeded to remove it and re-attach it several times. None of which broke it.
Step 6: The End
Congratulations! You have just finished your fire missiles button (or simply reading this instructables). So congratulations! If you have any other ideas for buttons, leave a comment.
Unusual Uses Challenge 2017
#Vanlife Contest
Makerspace Contest 2017
