3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Fire Skirt!
Step 4Supporting the power supply, making electrical connections
The power supply is attached to an elastic garter that is worn below the knee, allowing for freedom of movement and support for the power supply and batteries. Make sure to leave a short length of cord between the garter and the skirt so that it won't pull the wire when you walk.
Strip away the plastic coating at the end of the EL wire, and you will see one main thick wire that runs down the center, and two very thin wires that stick out around the side. The thin wires are fragile, so it is recommended to anchor them to a small piece of copper tape wrapped around the coated part of the wire.
Tutorials for preparing & connecting EL wire:
EL wire soldering tutorial from Cool Light West
MakeZine: Glowing Wearable Blinky-Light
see larger video
1 comment
Jul 19, 2009. 12:46 PMhardhat444 says:
did not give enough information
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
14
Author:la(Caballera.com)
art! www.lauracesari.com design! www.caballera.com
