Introduction: Fire Starter Box
A rectangle wooden box which allows air to travel through while the fire is still going on. 4 wooden planks hot glued together with a lever top so u can put it on. It could also act like an ember box(put something on the bottom) It is an easy fire starter and it keeps it going for about 10 minutes which allows you to get wood. You Can put holes in it if you want too.
Step 1: Things You Need
5 blocks of wood
Scissors
Hot Glue Gun
Hammer
Nails
Step 2: Putting It All Together
Get the hot glue gun and with 2 of the blocks of wood glue them together. Then Get 2 more blocks of wood and put them together(one on the right) (LOOK)
Step 3: Keep It Goin
Keep on Putting it together. look at the image!
Step 4: TADA!
Your Finished!!!
Step 5: If You Wants
If you want you can add the little piece of wood at the end.
Now that your done get some cotton or Tissue and get some matches or flint and steel and light those babies up. Once you get that started put it in the box and it should catch on fire. It will last about 10 minutes which leaves you enough time to get wood and build a big fire.
THE END!! GO PLAY WITH FIRE NOW!
