3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Fire Starter From Used Coffee Grounds
Nothing’s a bigger bummer on a camping trip than to run out of kindling and still have no fire. Let’s face it, if you’re camping anywhere they’ll let you have a fire, chances are the wood you’ll find is so wet you’ll need magic fire starting skills, gasoline, or a little help from ingenuity to get things going. Fire skills take a long time to learn and aren’t particularly reliable. Gasoline is dangerous. Let’s focus on ingenuity.
This fire starter uses old egg cartons, used coffee grounds, used coffee filters, matches, and paraffin wax to make some long burning, energy dense fire starters sure to get any fire going without the fear of singing eyebrows. I suppose any sort of biomass would work in place of the coffee grounds so long as it's flammable. Dryer lint is a great option. I suppose one could try old tea leaves or even old tea bags, but I can't imagine those would smell as good on fire as coffee grounds.
When you want to use these, you just cut off as many as you think you'll need, light them up under your wood pile, and you'll be well upon your way to roasting marshmallows.
These burn for about 15 minutes. Below is a video I took of one burning, but I cut it down to about 2 minutes for the sake of sanity.
Step 1Collect and Dry Your Material
Coffee Grounds, as you’re probably well aware, come out of the coffee maker sopping wet, so obviously they’re not flammable quite yet. But you may not be aware that they are quite flammable when dry. Simply collect them on a piece of newspaper and lay them out to dry. Make sure you don’t store wet grounds in a clump somewhere as they will mold quite quickly if left moist.
After collecting a few days’ worth of grounds, spread them out on a cookie sheet and bake them either in full sunlight, an oven set for 250 degrees, or a food dehydrator. If you use an oven, make sure you open the door periodically to let moisture out. If you use sun, don’t do it on a humid day. The point is to get as much moisture out of the grounds as possible.
Make sure you save the filters and dry those out as well, you'll be using them later.
14 comments
Mar 18, 2012. 11:55 AMautocthon says:
What a wonderful recycling idea
Jun 28, 2011. 6:48 PMCobyHoff says:
What is the approximate burn time of one coffee-egg-cup? Have you ever observed the burn time or apparent heat of one of these in comparison to, say, a lint-based fire starter? I love the idea of using old coffee grounds, I'm just curious if it offers any other advantages/disadvantages.
Oct 12, 2011. 2:17 PMJackJobe says:
Stay away from Dryer Lint.  It is mixed with Nylon, Polyester & other man-made materials.  That's NOT what you want to inhale.  For around a dollar, you can buy a huge bag of Cotton Balls.  The coffee grounds is an interesting material.  Keep Thinking and Experimenting.
Feb 9, 2012. 7:40 AMPACW says:
I tend not to worry about the man made materials in Dryer Lint. When you wash a load of cotton towels or denim jeans you get a lint trap full of lint. When you wash a load of nylon or polyester clothes you get very little to no lint. Which makes a bit of sense. . . one of the benefits of man made fibers is that they last longer - they're not always shedding fibers like cotton and linen and wool.
Jun 30, 2011. 3:45 PMCobyHoff says:
I need to buy some wax, and finish my carton of eggs, but I do have plenty of lint. It would be more accurate, I suppose, if I gave the lint to you, and you made it as closely as possible to the coffee one. Let me know if you want me to get the lint to you.
Aug 3, 2011. 9:23 AMidlymr74 says:
I just use candle stubs and broken crayons
Jun 26, 2011. 2:23 PMHeWantsRevenge says:
u need a video, of these in action
Jun 27, 2011. 9:38 AMPS118 says:
When you use them, do they smell coffee-ee? or like burnt coffee? or like nothing?
Jun 27, 2011. 12:07 PMPS118 says:
Too bad. But at least you get your fire lit, to make coffee on... so still pretty cool. :)
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
6
Author:josefski(Puddle Town Indie)
