3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Fire goo
video Fire goo
Some times while camping or hiking your lighter may not work or a fire way not light because you have no tinder. If a lighter wont light you may have to try to wrap a tissue with lint form sock ,shirt, pants, bellybutton :), put on tip of lighter ,spark and hopefully light to the goo. There is a product on the market called Coghlan's Fire Paste and is available but almost $ for a thing the size of a tooth paste tube.Always be responsible with fire http://media.rei.com/media/626906Lrg.jpg. Due to user coments I will say how to make step by step (note takes 30sec) 1/3rubbin alchol 1/3 third purell 1/3 magnesum bar shavings option
Add red die like in pic shake before use. Thanks for help comments
22 comments
Aug 16, 2009. 1:59 PMyokozuna says:
I think this would be better if you showed how to mix it, like you say you're going to do in description. Showing it used to start a fire would be good too!
Aug 20, 2009. 8:51 AMastrong0 says:
the cheapest thing ive ever made as to something like this is a 50/50 maxture of gasoline and acetone (paint thinner) then disolved alot of styrofome into it till it started to form a thick gel at the bottom
Aug 29, 2010. 12:37 AMshane55 says:
thats homemade napalm
Aug 5, 2010. 1:13 AMQuest for Questions says:
where's the video ?
Mar 25, 2010. 7:13 PMmedius says:
Excellent. Yeah, I saw the stuff at REI and actually though "Wow, that's expensive. Now I wonder if I could make this." Thanks for this vid. I'll have to try this.
Dec 3, 2009. 3:39 PMbennyb1 says:
Almost any tube of glue(Duco, model cement, etc) is flammable and easy to carry. Squeeze some onto your tinder, light, and you have fire. I used to cut cardboard into small strips, and soak it in melted parafin. A whole bunch of them fit in a plastic bag. If you get really cold and wet, just light 2-3 of them and warm your hands whever you are. I don't do as much hiking and packing now, so the glues easier.  The hand sanitizer bottle is probably less prone to getting crushed
Sep 24, 2009. 5:49 PMmaxpower49 says:
do you need the magnesum
Sep 7, 2009. 6:30 PM555mst555 says:
what's 1/3 third purell ???....
Sep 11, 2009. 3:45 PMItsTheHobbs says:
1/3 of the mixture is Purell hand sanitizer.
Aug 24, 2009. 12:02 PMmo5 says:
fire...goo,it's foo : )
Sep 3, 2009. 1:56 PMHiyadudez says:
Or Gire :)
Aug 23, 2009. 2:41 PMdagenius says:
Great video, and good luck, but it would havebeen better in my opinion if you actually had some video in there. Just look at all of the others.
Aug 14, 2009. 6:21 PMoakironworker says:
1/3 of a cup of MG shavings? IT would be cheaper to buy the paste wouldn't it?
Aug 12, 2009. 8:58 AMCaptain Dyson says:
dude i dont get it it goes past too fast and u cant see the stuff behind the words
Aug 12, 2009. 3:48 PMgeekazoid says:
gotta agree with chicken-bacon-cheese
Aug 14, 2009. 7:21 PMsaxmaster765 says:
This is what I do when using that kind of lettering. . . I would make is slightly transparent so you could see what was behind it, but opaque enough to see the lettering. Or simply not to use it at all. Try subtitles.
Aug 14, 2009. 9:46 AMCaptain Dyson says:
look I might vote 4 u if u gust put some instructions just a quick thing as a comment or something otherwise I don't think that anyone will vote 4 u
Aug 14, 2009. 9:47 AMCaptain Dyson says:
ahhhhh i see now hey this is good and i will vote when the polls open
Aug 13, 2009. 9:07 AMKilsmer says:
I don't know if you can re post this or what ever, but you should change the effects you used, a simple picture of what to use and a description of it would be sufficient. I know you only get 30 secs but its enough time to tell you what to do for something this simple. Nice idea though.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:quinn1221
