loading
loading
video Fire goo
Some times while camping or hiking your lighter may not work or a fire way not light because you have no tinder. If a lighter wont light you may have to try to wrap a tissue with lint form sock ,shirt, pants, bellybutton :), put on tip of lighter ,spark and hopefully light to the goo. There is a product on the market called Coghlan's Fire Paste and is available but almost $ for a thing the size of a tooth paste tube.Always be responsible with fire http://media.rei.com/media/626906Lrg.jpg. Due to user coments I will say how to make step by step (note takes 30sec) 1/3rubbin alchol 1/3 third purell 1/3 magnesum bar shavings option
Add red die like in pic shake before use. Thanks for help comments
Fire goo = napalm, napalm = ire goo.
yokozuna5 years ago
I think this would be better if you showed how to mix it, like you say you're going to do in description. Showing it used to start a fire would be good too!
the cheapest thing ive ever made as to something like this is a 50/50 maxture of gasoline and acetone (paint thinner) then disolved alot of styrofome into it till it started to form a thick gel at the bottom
thats homemade napalm
quinn1221 (author)  astrong05 years ago
bad that is dangerous dont do that try mine
where's the video ?
medius5 years ago
Excellent. Yeah, I saw the stuff at REI and actually though "Wow, that's expensive. Now I wonder if I could make this." Thanks for this vid. I'll have to try this.
bennyb15 years ago
Almost any tube of glue(Duco, model cement, etc) is flammable and easy to carry. Squeeze some onto your tinder, light, and you have fire. I used to cut cardboard into small strips, and soak it in melted parafin. A whole bunch of them fit in a plastic bag. If you get really cold and wet, just light 2-3 of them and warm your hands whever you are. I don't do as much hiking and packing now, so the glues easier.  The hand sanitizer bottle is probably less prone to getting crushed
maxpower495 years ago
do you need the magnesum
555mst5555 years ago
what's 1/3 third purell ???....
1/3 of the mixture is Purell hand sanitizer.
mo55 years ago
fire...goo,it's foo : )
Hiyadudez mo55 years ago
Or Gire :)
dagenius5 years ago
Great video, and good luck, but it would havebeen better in my opinion if you actually had some video in there. Just look at all of the others.
1/3 of a cup of MG shavings? IT would be cheaper to buy the paste wouldn't it?
quinn1221 (author)  oakironworker5 years ago
Sorry 1/3 of the ammount of you want to make hood point though It actually works well (vote 4me)
dude i dont get it it goes past too fast and u cant see the stuff behind the words
gotta agree with chicken-bacon-cheese
This is what I do when using that kind of lettering. . . I would make is slightly transparent so you could see what was behind it, but opaque enough to see the lettering. Or simply not to use it at all. Try subtitles.
quinn1221 (author) 5 years ago
Vote for me
look I might vote 4 u if u gust put some instructions just a quick thing as a comment or something otherwise I don't think that anyone will vote 4 u
ahhhhh i see now hey this is good and i will vote when the polls open
Kilsmer5 years ago
I don't know if you can re post this or what ever, but you should change the effects you used, a simple picture of what to use and a description of it would be sufficient. I know you only get 30 secs but its enough time to tell you what to do for something this simple. Nice idea though.
