Introduction: Fire Steel
Many people take a lighter or matches camping with them, in the past i've always found these to be unreliable. Whether its forgetting to refill your lighter or damp matches, i find that a fire steel and striker is much better. From lighting the gas stove to lighting a camp fires its my preferred method, it doesn't matter how windy or wet a modern fire steel will still produce sparks at 3000ºC and it won't run out of fuel.
I spotted a stack of fire steel blanks in an outdoor shop and thought id have a go at making a handle for one. I had the choice of deer antler or birch burl. I decided on the antler as it was a nicer shape.
Materials
Ferrocerium rod (fire steel blank)
Deer antler
Glue
Wax
Leather
Tools
Drill
Sander (Dremel)
Sandpaper
Engraver (Dremel)
Lighter
Materials
Deer antler
Glue
Wax
Leather
Tools
Drill
Sander (Dremel)
Sandpaper
Engraver (Dremel)
Lighter
Step 1: Sanding Off
I wanted a nice smooth effect for the handle of my fire steel, though you could just as easily leave it in its natural rough state.
I used the sanding piece on the dremel to remove the rough outer layer and sand in a thumb shaped dip so that the polished antler doesn't slide out of my hand when i strike it. This was all done with a rough sanding to P60.
Step 2: Drilling Your Hole
A fairly simple step. Choose a drill bit thats slightly bigger than your ferrocerium rod and drill a hole that goes deep enough for it to sit in without falling out.
I used an epoxy resin to glue my rod into the hole, but only because thats what i had around, most glues would suffice.
I placed the rod in the hole, wiped of any excess glue, clamped it in a grip and left it to dry for a few hours.
Step 3: Sanding
To give a better finish i used a variety of sandpapers (P100 to P250) to smooth of the antler. I also drilled a small hole in the top of the handle to tread a piece of leather through.
Step 4: Engraving
As a final little bit of decoration i thought i would add an engraved rune on the end of the handle. I chose the eldar futhark rune Kenaz (torch or fire) as it seemed appropriate.
Using a fine edged engraving bit on the dremel i carefully engraved the rune into the antler.
To fill in the shape of the rune i melted the end of a wax crayon, using a lighter, and dripped the wax into the rune. After scraping off the excess wax and fitting the leather strap and your good to go.
To use your fire steel simply run a hard metal edge (like that of a knife) down the length of the steel whilst applying some pressure.
