Fireant Plenum Robot
2,808
92
19
Posted
Introduction: Fireant Plenum Robot
This bot was built to work in plenum and other tight spaces.
I built this little guy two years ago to run Cat5/6 and coaxial cable through plenum spaces (open spaces above ceilings and under floors). Over the years he has seen quite a bit of action and has been an asset in any small space that requires a peek or a light hands-on approach.
Fireant Plenum Robot’s features:
  • 2.4Ghz color video camera
  • 2.4Ghz transceiver
  • Pan and tilt arm with claw attached
  • Ultra bright LED headlight
  • Buzzer for user location through surfaces
  • Rubber tank treads for improved traction
  • Built from sturdy, damage resistant fiberglass
  • Shock-resistant carrying case
This is an IBM/PC and Mac/Linux compatible serial device.
To operate the Fireant Plenum Robot, all you need is a computer that can accept a USB transceiver, and a program that can talk to Serial devices at 9600 baud. Such basic programs include Putty or if you want to get more creative you can use a layering program such as Processing to automate commands.
Remote Controlled or Automated Use.
The Fireant Plenum Robot has at its heart an Arduino Uno R3 with an Adafruit Motor Shield. This combination can either be used with the default sketch, which allows a controller via remapped keyboard presses to operate the built in devices, or another sketch that is coded to perform another predetermined task.
I know this is not a step by step Instructable but I have linked most of the parts in the text above. Feel free to use the attached code in nonprofit projects, as long as credit is given.
    • Science of Cooking
      Science of Cooking
    • Microcontroller Contest
    • Spotless Contest
      Spotless Contest
    19 Comments
    If you like this instructable, please consider voting for it above! =)
    What is the spare you have used here???
    this one... plus will I be able to know how you have connected this arduino board, shield, motors and the arm?
    Hello Reichenstein7,
    Will I be able to get the connection sketch (Schematic) for the above project. I am impressed with this project and I am doing a project as the same. So please be kind enough to help me
    The code is included at the end of this instructable. All you should need to do is copy it and paste into the Arduino IDE Software.
    when trying to compile it shows some formatting error! Will I be able to get your help regarding this? The error image is enclosed. Thank you
    It looks like the code really didn't like being uploaded as text. I have uploaded the same code (with a minor fix) in the official .ino file type.
    That is amazing. This works perfect. BTW if you don't mind can I know how you have connected this with arduino, motor shield, gripper arm and the remote controller?
    Thank you a lot
    Reichenstein7,
    Can I get the wiring connections sketch of the project. To try the codes the setup has to be correct in the exact same way as the you have connected. Plus :) I voted :)
