3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Fireplace fan
Fireplace fan
I recently installed a small gas fireplace. It's a great unit but it doesn't circulate heat very well without a fan. I wanted to improve the heat output and found this fireplace fan on the web. While the fan looked very professional, the price ($140) put me off. So I decided to build my own.
Materials:
  • Computer fans (2), $2.99 each, Newegg.com
  • Fan noise dampeners, $1.99 for a pack of two, Newegg.com
  • AC adapter / power supply, input 120V AC, output 12V 500ma, Model TEAD-41-120500U, $2.99, eBay.com
  • Panel-mount stereo 3/32" submini phone jack, $2.99, Radioshack.com
  • Steel sheet, 26 gauge, 12"*12". You can find this near the roofing and sheathing materials at Home Depot but basically any sheet that you can cut will work.
Tools:
  • Dremel
  • Soldering iron
  • Work bench
  • Drill and a drillbit slightly larger than the threaded part of the phone jack
  • Ruler and pen
Step 1Mark fan screw positions
Using the dampeners as a template, mark the position of the fan screws on the steel sheet. Leave about 1/4" inch between. Drill the holes. This will give you two squares.
32 comments
Jan 29, 2011. 10:11 PMcgfluid says:
That looks great! I'd love to be able to build something like that, unfortunately I'm not that handy. We've been looking for an efficient little fireplace for a little while now and finally came across one that looks perfect. We found it at http://www.comfortsolutionsutah.com, check their fireplaces out!
Jan 11, 2011. 11:17 PMyudystuff says:
craft foam will work as well
Apr 25, 2010. 7:44 PMteknomage2012 says:
I use one of those fireplace grate heat exchangers in my home as my primary heat source burning pallet wood. I got it from hastyheat.com one of the things to note is they have these die cut ceramic fiber insulators similar to the silicone gaskets used here only they can handle much higher heat, insulate the fan better and since they are die cut they have 4 little arms and a center patch that covers the fan motor protecting it from heat, I will add a pic to best describe. Something you might consider as it seems more appropriate to the application.
Jan 31, 2010. 6:35 PMbobinette says:
how safe is it to use phone jack to connect the ac/dc transformer to the fan?
Jan 31, 2010. 7:47 PMKT Gadget says:
 Thats what i thought too when i used 2 12v PC fans (with 1 A running) but it actually works well. The only concern is the plastic melting and the 2 contacts making connection, hence a short circuit, due to the heat of the fire. For a safer channel, run a chute (or square tube) made of metal to the back and then have it point to where you want the heat.
Aug 7, 2009. 12:03 PMsolow75 says:
This is not my idea, but I thought I would throw it out there. Epoxy a thermostat to a magnet and attach to the bottom of the firebox. When it gets hot it will turn the fans on and they will stay on until the fire cools.
Jun 9, 2009. 11:41 AMReCreate says:
You Can Get Fans From an Old Computer, You Can Get the Metal From an Old Computer's Casing, and You Don't have To buy a New Adapter/Wall Wart/Power Source You Likely Have Around Collecting Dust, And If you Don't You Are Likely To find someone throwing one away. ~ReCreate
Dec 17, 2007. 7:38 PMGorillazMiko says:
cool, looks very very nice.
Jun 9, 2009. 10:05 AMdmason88 says:
For you electricians out there, do you see any problem with putting a dimmer switch to control the outlet in the fireplace? Would that not give better fan speed control?
Mar 4, 2009. 8:03 AMenergygeek says:
When I first read this title of this thread it scared the crud out of me, (make your own fireplace fan = certain death by flames) but now that I see how you made it and the application....looks like a keen idea! Good job.
Dec 21, 2008. 8:10 AMhybridracers says:
Great tutorial, very cleanly done (unlike some builds on here) and well thought out. Im impressed as I have actually built one of these (8 fans wide) for my wood burning fireplace that was hugely innefective at warming the entire house. Airmovement is critical if you want anything more than a body magnet like most fireplaces are. Good job!
Dec 21, 2008. 8:06 AMhybridracers says:
clear aquarium silicone sealant lightly "painted" on the non showing sides of sheet metal also dampens noises and vibrations.
Dec 21, 2008. 8:03 AMhybridracers says:
A little less time consuming way is to just buy the right size hole saw from your local big box home improvement center. Make sure you clamp the metal sheet to some wood with your holes and some screws. Rotating sheet metal is dangerous
Dec 21, 2008. 8:01 AMhybridracers says:
or do what I do and run your marking tool around the inside of the fan case following the blade. gives you the exact cutout needed.
Oct 23, 2008. 7:26 PMlithoss says:
This looks awesome.. one question though, is nobody worried about the fans getting too hot and partially melting and/or causing a fire somehow? Maybe I'm just paraniod,... anyone want to put my worries to rest?
Sep 17, 2008. 6:56 AMscotiadallas says:
I love this fan, it's been bookmarked on my browser for over a year and this weekend is the big weekend. I'm going to build two of them. I have a question. Is there a simple way to put these fans on a remote control or even better yet, a thermostat? Anyone have any ideas? D
Sep 18, 2008. 3:18 AMscotiadallas says:
Thanks for the input! I haven't ordered my fans yet so I'm going to look into this. Surely the temperature below the firebox will trigger these temperature sensitive fans! Another question. While gathering parts I realized that there is a harness wrapped up in the middle of your intro image. Does this harness come with the fans or is this an extra item? My original though was that I would cut the white end cap on the fan and just solder those but looking closely it seems the harness is a larger gauge wire? Any input would be appreciated.
Dec 26, 2007. 1:23 PMcubeberg says:
How did you decide what adapter to use? Would the adapter you purchased be capable of running 3 fans?
Jul 7, 2008. 10:40 PMliquidsense says:
In you items list, you suggest using an AC adapter. And here, you suggest DC. I'm not very sure what the difference between AC and DC is, but what should I use for this setup? I also have two 12v 0.16A fans. THanks!
Dec 17, 2007. 7:25 PMLinuxH4x0r says:
Nice Job! Instead I would reccomend having the fans blowing air into the bottom thingie. This way it is blowing cold air in, instead of hot air out, minimizing the chance of melting.
Jan 2, 2008. 8:10 PMkarnfamily says:
This sounds great. I'm going to try one for a masonry fireplace channel heat exchanger. Just one question, what resistor would you use (including maybe a variable Rheostat.
Jan 2, 2008. 9:23 PMLinuxH4x0r says:
If you are using low voltage dc computer fans just use a transformer with a lower voltage (try maybe a nine volt or maybe even 7.5)
Feb 27, 2008. 9:36 AMandydumi says:
Thats what I am doing. Running two of them off of a couple 9V batteries. My fireplace does not have a power plug as the one shown. I have wired the fans to 3 9v batteries and they are switched on/off by the switch controlling the fire (remote control switch) . So when the fire is on, the fan is on. The batteries last about a month, and then I just recharge them.
Dec 20, 2007. 7:54 AMurbanhg says:
very good idea i work as a chimney sweep and buying a blower for your stove can be expensive so way to save some $$
Dec 19, 2007. 11:17 AMHaymaker007 says:
Nice job, especially the use of the Workmate as a brake for metal bending (I have to try that). I use a similar setup with a wood stove, fans are 12v DC, connected to a battery for the night and a small solar charging array for daytime, the 200CFM projects a nice heat. I cannot hear them so I wonder if yours are vibrating the base in spite of the furniture pads, or perhaps the front is laying against the back wall of the stove case (just ideas)? For information make sure of the airflow direction of the fans and the volume of air is not overly cool for the firebox (although I do not know the science re firebox temperatures/exhaust for gas stoves).Pulling cold from the bottom up and/or pushing over the firebox is the way to go. ultimately it is the distribution of btus into the room.
Dec 18, 2007. 11:29 AMcubeberg says:
Absolutely awesome! I just moved into a new house with a gas fireplace and was looking for something like this. I'll have to build my own!
Dec 18, 2007. 4:08 AMBrennn10 says:
This is really good. It looks really sweet. Nice job!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:antarctic74
