Remove these ads by
Signing UpStep 1THINK!!
First, go to a website which is legal and used a lot. Think! Should you use that homepage that the teacher will question why have you not made any progress (you been on that page for hours)? Will the scroll bar being of a larger page that it should be give away your secret (Google's homepage does not and should not have a scroll bar since it is one page)? Should you use the homepage or an article (to make a teacher think you are working)? Finally, does the webpage include anything that will be hard to visually duplicate offline?
Second, after you have your webpage picked out, construct your offline copy. If you have Internet Explorer 6, click on View and then Source. A Notepad application will open up with HTML coding. In the Notepad window, click on File and then Save As. Save the file to a USB memory stick or CD-RW. You can either learn HTML (not suggested for most) or you can use an authoring software. Microsoft Word can be used. Even if you copy the page and manually edit it, you will haev to manually copy images and change the source of them. If you use anything to edit the page, make sure that your filetypes are compatible. You may need to learn new skills or leave to the nerds to make and distribute. Your goal is to create a webpage that is visually the same.
7
comments
Add Comment
Add Comment
