3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
.50 CAL Ammo Box Firework Controller Build
  • last photo ←
My version of systemf92s Fireworks Controller. 12 channels crammed into a .50 cal ammo box. I used speaker binding post instead of spring terminals. Most of the work was put into drilling the holes and soldering. The hole top right was unused but was going to be for a power jack to charge the battery but never got the part.
The panel is brushed 20g steel with a clear coat to prevent shorts.
17 comments
Jul 2, 2011. 9:14 AMrick.leasure says:
Great pictures, but where's the documentation?
Jun 10, 2010. 3:33 PMdemonxkid says:
if you want a easy to make igniter that you can reuse just use a spring
Jun 30, 2011. 7:45 AMjmcbrayer says:
like it thanx
Jul 7, 2009. 4:18 PMPadlock says:
What did you use as an ignitor? I made some simple nichrome wire ignitors, but they were tedious to make.
May 6, 2010. 6:24 PMsystemf92 says:
How is the 18g copper wire working out for you? Is it pretty reliable? I am currently trying to find something more reliable than the steel wool method.
Jul 12, 2009. 6:36 PMmacgyver603 says:
Something that also works is model rocket igniters. They are somewhat cheap, and you do not have to make them.
Jul 5, 2010. 2:17 PMCameronC says:
I bought a large bundle of florists wire - glows white and melts with 12v - wrapping it around fireworks fuses works surprisingly well, although homemade e-matches are more reliable.
Apr 16, 2010. 2:32 AMArirox says:
Hey, I Relised That You Have The Leds With Your Switch Wired So When You Have It Off But The Key is Turned On The Lights Are Off When The Switch Is Off But When U Change From off To On It Turns On The Led And I Need Some Help Wireing Like That I Am Useing A 9v  Battery For My One And I Will Create A Instructable When I Get The Parts Tomorow But I Need To Know How To Wire That And Also I Saw This In System93f's Comments So I Had A Look Great Job Bro Just Get Back To Me Asap
Sep 20, 2009. 1:31 PMjoekickass345 says:
can someone please write a list of things you have to buy for this i have the ammo box already(YES)
Jul 23, 2009. 10:23 AMspeedyzeek says:
good job reminds me of mine i build about a month ago only difference is that mine is crammed into a 30 cal ammo box and i have a 12v 7.5 amp (20 hr) battery in it, but mine only does 4 channel but i have a delay timer in it so i can have delays from .01 secs all the way to about 48 mins
Jul 11, 2009. 12:45 PMPyroMonger says:
How did you get the LEDs to be lit only when the corresponding terminals are in use?
Jul 17, 2009. 6:59 AMPyroMonger says:
I get it now...thanks. I can\now proceed with building my own version
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
25
Author:Rob K
