3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Fireworks Igniter
Fireworks Igniter
These electronic igniters will reliably light any firework with a fuse on it. They are designed to use in conjunction with my Fireworks Controller, but can be used with any electronic controller that you may have built already, or even any 12v battery. They are relatively simple to construct and are made of common materials already available in your house or at a local hardware store. You don't need nichrome wire to construct these igniters.
Use these igniters ONLY IF:
  • It is legal to launch fireworks where you live
  • You are using factory/store bought fireworks
  • You are far away from dry grass
  • The launching area around the fireworks is clear
  • There are adequate safety features on your controller to reduce the chance of an accidental detonation while connecting the igniters
The author (Systemf92) is not responsible for any accident, damage, legal trouble, encounter with law enforecement or death that may occur from the use of these electronic firework igniters. Use at your own risk.
Step 1Acquire your materials
The parts you will need shouldn't be to hard to find, if you don't have them around your house, then your local hardware store should carry them.
Parts Needed
  • Any small gauge insulated hookup wire, stranded or solid, around 20-24AWG (Size doesn't matter that much, as long as the gauge is not smaller than the steel wool you will be using. You will need about 6" per igniter.)
  • Matches, one per igniter
  • Electrical tape
  • Grade #3 steel wool (commonly used to remove paint and clean engines)
Tools Needed
  • Scissors (or teeth, for cutting electrical tape)
  • Wire strippers (if you don't have any, try using scissors)
79 comments
1-40 of 79next »
Apr 6, 2012. 8:24 AMhaunce says:
' been there done that (or at least real similar). This approach works, but has some reliability issues. I recommend using 10 ohm resistors as ignitors. Stupid easy, 1 part, and 100% reliable.
10 ohm 1/4 watt carbon filament ~ 10 cents each.
ohms law states @ 12 volts you will get 1.2 amps across the resistor- pretty easy on your ignition system. I have no trouble lighting visco (the thick green stuff) with this set up.
Feb 6, 2012. 5:44 AMemadsiddiq says:
http://www.instructables.com/id/Make-a-bomb-no-potassium-nitrate-used/
OR
http://hacknmake.blogspot.com/
please read it and comment :)
p.s i am 13
Jul 6, 2010. 8:20 PMstatic says:
An interesting approach, but here I would think the breeze would blow out the match before it lit the fuse.
Oct 3, 2010. 4:16 PMrrrmanion says:
i find a small amount of something flammable such as aftershave or deodorant works really well to prevent that.
Jun 30, 2011. 2:47 PMkscience says:
actually- a dipped tantalum capacitor, wired reverse polarity will ignite nicely from a 12v gel cell; it will also stay lit, as I found out once on a project that was not supposed to ignite. :P
Sep 30, 2009. 6:53 PMpyra_builder_1337 says:
another way to do this is to take the wire setup and place it on a piece of celophane pour a SMALL amount of BP on it and cover with duct tape leaving some of the sticky part over the plastic so you can tape it to the explosive device
Jul 3, 2011. 11:43 AMjongscx says:
British Petroleum? do you soak it in gas?
Jun 30, 2011. 1:12 PMbryan3141 says:
BP would be?
Bryan "clueless" Paschke
Jul 3, 2011. 11:55 AMMikrySoft says:
Black Powder
Jul 4, 2011. 12:57 AMbryan3141 says:
doh...in context that makes sense....should have been able to figure it out. Thanks.
Bryan "truly clueless" Paschke
Apr 5, 2011. 5:20 PMDannytheGreat says:
why dont you just let the wires arc?
Jul 3, 2011. 8:29 AMMPaulHolmes says:
The power supply would have to be too high a voltage. That would preclude using a regular 12v battery as the power supply.
Jul 1, 2011. 9:50 PMriverreaper says:
so it works like a taoster ? that seems like you couldent have a timed show very well , what if you just went to the goodwill an bought some old cheep toaster took it apart sthech the heat coils out to form a line use a bit of sotch tape to hold fues to it sat back at the house with the ectetion cord an pluger it in lol
Jun 30, 2011. 7:38 AMBlueFusion says:
This seems to be remarkably familiar to my (very old and poorly made) instructable from 4 years ago :)
http://www.instructables.com/id/Simple-cheap-pyro-igniters/
Except yours is more complex. I've made some changes to my design - maybe I should republish!
Nice work though.
Aug 5, 2010. 1:44 PMemmick4 says:
wouldn't it be easier to simply put the fuse where the match head is?
Jul 5, 2010. 5:38 PMPyromanX says:
How about sticking the end of this in a wire nut, then twist the fuse up in there too?Is it too big?
Oct 3, 2010. 4:17 PMrrrmanion says:
i think that might work with the right sized nut,
Jul 14, 2010. 3:49 PMMACKattacksnipe says:
Get some of those model rocket ignites
Jul 5, 2009. 8:21 PMJerimiah40 says:
How would you recommend attaching this to the actual firework?
Jul 6, 2010. 5:28 PM3001515562 says:
i made this and tried it with a fuse and it worked fine. it took about 1 sec longer but it worked
Sep 2, 2010. 12:29 PMrrrmanion says:
if it is a rocket, attach a small piece of metal to the firing tube (the thing you stick in the ground) then attach assembly to that, and put fuse in position. i think this will work fine
Jul 8, 2009. 7:39 AMbowmaster says:
Have a bit (~1 inch) of steel wool hanging off. Then wrap it around the fuse.
Jul 16, 2009. 1:38 PMpontiacking says:
If you wrap a 1in. pice of fuse to the match win you wrap the match head with steel wool you can tape the fuses together
Jul 2, 2010. 5:03 PMairsoftjunke says:
i am having troble ignighting the match head using a 12 v battery from my switch bord any sugestions?
Jul 3, 2010. 9:51 AMAZombieHippie says:
i have a suggestion dont use alot of steelwool it will not heat up and glow to the point where the match catches fire
Jul 3, 2010. 5:57 PMairsoftjunke says:
i am only using one strand of steel wool and it seems that there isnt enought currant flowing through the 15ft wire to heat up a copper fillament i use instead of steel wool
Jul 3, 2010. 10:25 AMAZombieHippie says:
Thanks systemf92 for the awesome tutorial i included your idea in this project i made called the ultimate detonator : )
Jun 30, 2010. 6:32 PMtechnodude92 says:
Cool idea. and I applaud your use of common household items. I've seen a few tutorials on different ignitors but most call for nichrome wire or flash powder(or both!), but this is nice, simple, cheap and readily available.
Jun 29, 2010. 4:07 PMstocky says:
Could you use Fuse wire instead of cotton wool as a love amp one with a car battery or any high current battery would result in constant fires, you could also use different thickness/current wire depending on how long you want the heat to last.
Jun 28, 2010. 8:51 PMsupernoeva says:
I know it's more expensive, but wouldn't nitinol wire be reusable and more consistent than the steel wool? This is the stuff I am talking about, http://unitednuclear.com/index.php?main_page=product_info&cPath=28_42&products_id=369 and when it shorten from the heat it'll break the circuit.
Aug 22, 2009. 6:01 PMfunwithfire93 says:
y uses aligator clips y not use longer wire? and im trying to rig aton of them together do u have any suggestions
Jun 27, 2010. 10:33 PMamoliski says:
A longer wire can only be used once before it has to be rewound/taped with the alligator clips, he can have one long wire that fires as many igniters as he wants to make. It is kind of like making a new gun every time you fire a bullet. Replacing as few parts as possible makes it cheaper and faster!
Jun 27, 2010. 1:31 PMBiohazard1194 says:
I'm probably going to make a few of these this year. Great instructable, very clear instructions and photos!
Apr 17, 2010. 7:45 PMaeronut01 says:
Nice descriptions, clear photos, awesome instructable...... why isn't this a freatured instructable yet?  Great job!
Oct 3, 2009. 10:15 AMakanan says:
I had 4 9v batterie in series. And it didnt light the match. i have the exact same steel wool why?
1-40 of 79next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
67
Author:systemf92
