First Electronics Project LED Show.
440
4
5
Published
Introduction: First Electronics Project LED Show.
About: Student with enthusiasm in engineering and design.
This is for beginner who has never get their hands on electronics and programming.
So first things is to get the materials.
[MATERIALS NEEDED]
1. Arduino Uno
2. Breadboard(Optional)
3. Wires and jumper wires.
4. 4 channels 5 volts relay.
5. DVD and CD
6. 220V LED lights
7. Cello Tape
8. Mirror
9. Screw Driver
Step 1: DECORATING LEDS
//DECORATING LED LIGHTS//
Use the DVD,CD,LED strips,mirror etc with creativity to create awsome environment.
Step 2: Wiring Arduino and LED.
//WIRING ARDUINO AND LED//
Connect 5 volts from arduino to VCC of relay.
Connect GND from arduino to GND of relay.
Connect Digital(PWM) from arduino 2,3,4,5 to relay 1,2,3,4.
Connect PC and arduino through USB.
Step 3: Wiring LED and RELAY.
//Now for LED wiring//
Connect one end of led strip to 220 volts supply.
Now connect one end of led stip to common port of relay.
Now connect open port of relay with 220 volt power supply.
PRECAUTION!!!!
All GND end of LED strips should be plugged in one common terminal of 220 Volts supply.
All wires from open port of relay should be pulgged into one terminal of power supply.
Do not mix wires from relay and GND wires from LED to common terminal other wise results will be not as been expected.
Step 4: CODING PART
//CODING//
Will explain the basics of coding in another tutorial. For this providing the source code as attachment file.
// IN THE LAST providing THE Glimpse light show//
Sorry for bad video quality.
Step 5: Enjoying the Show(video Links)
https://youtu.be/C6ZJkkNwNdc
    • Clocks Contest
      Clocks Contest
    • Oil Contest
      Oil Contest
    • Woodworking Contest
      Woodworking Contest
    5 Comments
    That's a fun way to make a homemade light show :) This could be neat for a party!
    I request to share links with your friends.
    So they can know video links are live now
    Video links are live now.
    You can watch now.
    And
    https://youtu.be/2ori0QGbh8s
    Yes sure.
    Sorry for the way I provide video.
    A good thinking of decorating your room and also to compete in such contests. Nicely done! I like it. Good start,you will go at great heights of reaching in Future.
