3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
First Lightsaber build (from stuff laying around) UPDATED
Like the title says. This is a build of a lightsaber. I built it from stuff laying around. I have not made a lightsaber before so wanted to see how this one would turn out. I had no plan just some crates of plumbing, lamp parts and computer parts. Most of it old or found items.
I lucked out as most the pieces just fell into place and didn't need much modding. Each picture is annotated with what I did exactly with each piece.
Parts needed:
Pop up drain assembly
brass knurled nuts x2
small brass screws x2
Lamp bits
broken toy (for the red button and the spring under it ripped out of the battery compartment)
Hard drive rotor
chrome faucet handle cap
Pack of faucet washers (mine was an old pack of assorted washers)
Knob from a bathroom faucet (all I had were the two knobs and no name on them)
a covering for the flexible part from a broken lamp
rubber plug ( i think it was to block a pipe temporary while working on it )
chunk of shiny red plastic from a sled. (
Tools used:
Dremel
Drill
bit of sandpaper
hairdryer
some liquid dish soap
drill mounted hole saw
drill bits
workmate (a portable work bench that can be used as a vice
Step 1Main tube
Main tube
I started off just taking all the bits and pieces I had and messing with them till I could see what would fit well together. I ended up with almost the whole thing assembled before to long, I only had to sand down the rubber stopper with the dremel, drill the drain plug, tear apart an old toy, and drill through the upper part. So I'll just go through each picture and explain.
35 comments
Oct 7, 2010. 2:36 PMking kolton9 says:
what is the name of that exact site but without that side with advertisements and stuff
Mar 22, 2010. 10:15 AMdedoweb says:
Sorry... this is the real light? I Don't believe.
Jun 15, 2009. 2:55 PMlobo_pal says:
Add an LED and enter the contest, I'll vote.
Jun 29, 2009. 8:48 PMlobo_pal says:
It's real easy, just get an led and one of those small round batteries and tape it. When you press on it and complete the circuit it lights up. You can do it in two seconds. But if you really don't have the time then that's too bad.
Jul 4, 2009. 8:33 PMseyonne90 says:
To make it black couldn't you use electrical tape, it would also seal them in place so they wouldn't move without changing the look of the saber at all.
Jun 15, 2009. 2:50 PMlobo_pal says:
I love junk buckets. So useful.
Jun 15, 2009. 9:03 PMnoobiefied says:
Not bad Pretty neat but i dont like the handle grip >:O yucky colour
Jun 16, 2009. 6:17 PMhayleemomo says:
u had that stuff just laying around!! lol
Jun 14, 2009. 3:54 PMXellers says:
Add in a small high voltage AC power supply and an old fluorescent or neon tube, and it will light up when you touch something with it.
Jun 27, 2009. 3:24 PMXellers says:
That's how the expensive models work. This is constructed very nicely, and with the small addition it could sell for hundreds.
Jun 15, 2009. 6:56 AMacidbass says:
freakin awesome you have learned well make you jedi knight i shall
Jun 13, 2009. 6:56 PMtherefplosion2440 says:
well thats not epic at all...its just amazingly freakishly awesomeling (<-- not a real word in case you needed clarification) epic great job!!
Jun 12, 2009. 2:03 PMNotbob says:
For stuff laying about your house, you have done an amazing job! I congratulate you! The only improvement; paint the blue/gray grip piece an silver/gray colour.
Jun 14, 2009. 10:23 AMpurduecer says:
Throw one of these in there
Jun 11, 2009. 2:04 PMtrm915 says:
Does it work
Jun 14, 2009. 12:45 AMjaketheman987 says:
lol
Jun 13, 2009. 10:27 PMkeikothemeowmeow says:
The force is strong with this one.
Jun 13, 2009. 10:25 PMfrogmeetcog says:
Smeggin FANTABULOUS.
Jun 11, 2009. 12:00 PMac1D says:
Why not put a 200mw red laser in there, with a translucent tube, I did it and it look like a lightsaber.
Jun 11, 2009. 4:47 PMluvit says:
a jedi you are. ...do or do not. ..there is no try. -grover
Jun 11, 2009. 3:20 PMIkearat says:
I was 17 when the first Star Wars movie opened. I waited in line about 14 hours to get in and then went right back and got in the line again after watching the movie. Myself and all our friends then spent the next several years enthralled by the experience. We built parts of robots, took florescent lamps and powered them with inverters inside pvc tubes, everything you can imagine trying to stay in the afterglow. Your Instructable is a creative and refreshing burst of some of those days. Thank you :)
Jun 11, 2009. 10:52 AMstephenniall says:
Very nice job looks very real
Jun 11, 2009. 8:15 AMMr. Rig It says:
Nice job and great use of materials!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
21
Author:TheGeekFather
