This Instructable will show you how to design and build your own Ripstik that "sticks" out in a crowd. Since it looks like a fish, I call it the FISHSTICK.
The torsion bar is hidden underneath the board and is basically made of a door hinge combined with a very stiff blade of a saw. It took me quite some time to get the "stiffness" of the board right, but with this set-up, the feel of the board comes very close to that of an original Ripstik.
Wolfshade has posted an I'ble on how to build a Ripstik back in 2009. Check it out here because I learned some aspects of it.
The motivation for this project came from the fact that all Ripstiks look alike. Secondly, the design of them simply resembles of two canoe paddles connected by a rod. Can't this be improved?
Remove these ads by
Signing UpStep 1What do you need?
- A plywood sheet to make the deck (90 cm x 35 cm x 0,9 cm)
- A pair of casters and a pair of wheels (diameter 7,5 cm).
- 2 Wooden blocks to connect the wheels (the base of the caster is 6x6 cm, hence the block must accomodate this size).
- A door hinge: width 8 cm (open), length 9 cm.
- A bolt (length 100 mm, M10) with a nut. This will replace the pin in the hinge.
- 8 screws for the hinge (shorter than the thickness of the deck, in my case 9 mm)
- 8 screws for the casters: a set of long ones (25mm) and a set of short ones (15 mm).
- 1 bolt, a washer and Tee Nut. (all based on M6).
- A blade of a saw, 14" x 1 3/4" X 0.062, and cut it to a length of 25 cm. I used one of BLU-MOL (works excellent). You don't have to use a saw, just as long it is a strong and elastic piece of metal. Some putty knifes are excellent alternatives.
- 8 Dowel pins (6 mm diameter).
- Masking tape and paint.
Just to be sure: you realise that it has been modified? (compare pictures of step 1 and 4).
I would recommend to stick as much as possible to the waveboard design (although I don't know what you mean with weird. Are they hooked or something).
I have made a comment on Nov 30 (12:12 am). Please read item 3. It's partially about the angle. Then feel free to come back with more questions.
I haven't posted a video yet, but I'm planning to. Now the streets are either very wet or covered with snow.
I have chosen for a Tee Nut as an ordinary screw IN the deck wouldn't be as strong.
The varnish layers are the type used in parquet floors (so designed to withstand the wear from shoes). So far the only damage is underneath the board from laying around on a floor.
But all homonym related jokes aside, kudos to this new and (more functional?) design!
http://tinyurl.com/26evo7f
I was just curious as to if the top was slippery or anything. Amazing instructable by the way, so simplistic but efficient!
If you're finished, post it and I'll send you a patch.
Approximate figures:
Plywood € 7
caster blocks (2) € 4
Casters (2) € 30
Saw € 8
+ paint
Although I'm not a very experienced "ripper" (just built the board for my son) I can see some differences and similarities:
1. The torsion (stiffness) is very much like a ripstik. I have spent quite some time to get that right.
2. As the wheels are larger (75 mm), the ride tends to be "smoother". The texture of the road (roughness) seems to have less effect.
3. Since the wheels are larger and I wanted to limit the height of the board, I have tilted the wheels slightly more than an ordinary rispstik . It seems that this makes the board a little bit less manoeuvrable, but more stable at higher speeds (it slightly favours going in a straight line).
If you are able to disassemble the torsion bar you can find out what the problem is or how it can be fixed. Isn't there some forum on the Internet that deals with ripstik problems?
Did you figure out how to make the twisting part alone or did you get help? Anyways, I really want to build this, it also looks fairly simple.
However, since I was not really limited by the size of the saw, I could choose one that provides a fair amount of torque (something Wofshade has complained about in his own I'ble). The amount of torque is determined by the length, width, thickness and alloy of the blade.
Study his Instructable and you'll see whay I mean..
