Fishtail Paracord Bracelet
Published
Introduction: Fishtail Paracord Bracelet
How to make a Fishtail Paracord Bracelet with pictures. You will need about 10 feet of paracord, and a Paracord buckle. You also need a lighter and some scissors. This will take 10 to 15 minutes once you have your supplies.
Step 1: Fishtail Paracord Bracelet - 1
Attach the paracord to the buckle and measure it on your wrist for size. If you want to make a 2 color paracord bracelet, just melt the ends together. Note, this braid is easier to make on a paracord jig.
Step 2: Fishtail Paracord Bracelet - 2
Take the first piece of paracord, and run it in between the two center colors. Make sure you have both ends on the same side like in the picture below.
Step 3: Fishtail Paracord Bracelet - 3
With the second piece of paracord, go over the, in between the 2 center pieces of paracord, up around the far piece, and back in between the 2 center pieces of paracord. Note, both the paracord ends should end up on the same side each time.
Step 4: Fishtail Paracord Bracelet - 4
Now with the first piece of paracord, bring it over the top, in between the two pieces of paracord, up around and back in between the two pieces of paracord. Note, make sure you pull the slack after each braid.
Step 5: Fishtail Paracord Bracelet - 5
Again with second piece of paracord, go in between the center pieces of paracord, up around and back into the center pieces of paracord, so you end on the same side you began on.
Step 6: Fishtail Paracord Bracelet - 6
Keep Braiding the Fishtail Knot until you reach the other buckle, remember to pull the slack out after each braid, and make sure you end up on the same side each time. Once you reach the other buckle cut and melt the ends of the Paracord. Now you Fishtail Paracord Bracelet is completed.
    • Oil Contest
      Oil Contest
    • Woodworking Contest
      Woodworking Contest
    • Casting Contest
      Casting Contest
    You can do this with shoelaces for practice and a new way to tie shoes!
