Fishtail Rubber Band Bracelet (no Loom Needed)
Introduction: Fishtail Rubber Band Bracelet (no Loom Needed)
Step 1: Gather Materials
-Rubber Bands (as many colors as you wish)
-S or C clip
-Your fingers!
Step 2: First
First get your first rubber band twist it to make an infinity sign put your finger through each hole
Then add two more bands (do not twist these)
Step 3: Getting Started
Now grab the bottom band from one side and put it over your finger it should end up in the middle. Do the same for the other side's bottom band
Step 4: Putting on the Clip
Grab the band you just put in the middle and just slide in the clip
Step 5: Just Keep Adding
All you have to do is keep adding bands always taking the bottom band and putting it over your fingers
Step 6: Don't Forget to Stretch
Be sure to stretch it out every so often so you can start getting the length you want
Step 7: Finally
After reaching desired length pull the last two bands and slide in the other side of the clip
    • Trash to Treasure
      Trash to Treasure
    • Paper Contest 2018
      Paper Contest 2018
    • Pro Tips Challenge
      Pro Tips Challenge
    Really good to help me out with making it. I needed to know now I do! !!!!!!!!
