iImage Information
You have a project that requires you to weld tubing together at a right angle, but you do not have any commercially made equipment for cutting a nice concave in the end of a tube where it joins another tube. This Instructable will show you how to do a good job in your home workshop.
I do not like welding EMT (conduit). I am using it here solely for the sake of illustration. What this Instructable demonstrates would work well with black pipe.
Step 1My setup
iImage Information
I am using a metal cut-off wheel mounted on a radial arm saw. The metal tube rests on a small accessory table I made.
I see you are a quite new member of Instructables. One thing you will learn is that many of us do not have a welder. I am very thankful that I finally do. I try to be cautious about publishing things that require a welder. When I can I suggest ways someone without a welder can complete the project I am describing. Even when I do a project that requires welding, I try to remember many who might read about it will not feel left out. Perhaps you might do an Instructable on your way of making coped joints for metal tubes.
(Wow, that's a lot of money for just a hole saw and clamp!)
I do not recall him mentioning about grinding off the zinc coating. i DO recall him mentioning that the welding fumes from galvanized were a huge problem. They made every effort to avoid the fumes (masks, etc...) but also he said to drink a lot of milk to absorb and counteract the effects from breathing the fumes.
Mike Bynum
With all due respect, that is a huge amount of preparation and set-up when you are already using a tool, your radial arm saw, that will make a perfect coped joint with only two quick cuts. Here is a link showing how: http://www.pirate4x4.com/forum/showthread.php?t=456800 Everything you need to know is in the first two posts. For other than 90' angles, pay particular attention to the last paragraph of the quote in post #2.
Also, for a more elegant solution, try these two links: http://www.ozhpv.org.au/shed/tubemiter.htm and http://www.metalgeek.com/static/cope.pcgi The first link is for the Tube Miter calculator by Giles Puckett or Eric Fahlgren, not sure which, as an aid to crafting bicycle frames. It allows you to print out a full size paper template to wrap around the tube(s) you are coping, then simply cut along the line.
The second link is an updated version which even allows you to offset the center axis of the two tubes from intersecting each other.
I hope this is useful information,
Mikey B.
