Introduction: Fitting Our Replacement Door Lock Springs Land Rover Discovery 1 Range Rover Classic TAIL GATE
Picture of Fitting Our Replacement Door Lock Springs Land Rover Discovery 1 Range Rover Classic TAIL GATE
Struggling to unlock your Land Rover? Turning the key and pulling the handle to open your doors? Or fed up of holding up the latch to open the doors? The poor quality springs within your door lock mechanisms wear and can even snap causing these symptoms.
The springs within the door lock actuator mechanisms deteriorate over time, the OEM spring is made from cheap metal which wears quickly, this wear leads to the symptoms noted above.
Fit our improved design Stainless Steel Springs and restore your door locks to full health for good.
Made from high quality Stainless Steel (will not deteriorate over time like springs offered by some others) our improved design thicker wound springs will restore your lock and will not deteriorate over time like the OEM part. Save the cost of a replacement actuator that will just fail again!
Range Rover MK1 Classic 1970-1996
Land Rover MK1Discovery 1989-1998
Step 1: Remove Door Trim
Picture of Remove Door Trim
For instruction purposes only this repair is carried out on the bench, this repair can and should be carried out in situe on the vehicle.
Remove the 6 screws and remove the speaker grill.
Remove the 4 screws and remove speaker trim.
Remove the 8 screws around the speaker / amp unit and remove.
Remove grab handle by unscrewing 2x 10mm bolts.
Remove the latch lever plastic surround by holding open the lever and unscrewing the screw underneath. Slide the plastic trim out.
Now prise away the door card, start at the base of the door and work around the trim until free.
Step 2: Remove Linkages
Picture of Remove Linkages
Remove all linkage rods.
Step 3: Remove Latch Lever
Picture of Remove Latch Lever
Unscrew the latch lever and twist linkage out of position.
Step 4: Remove Pivot Point
Picture of Remove Pivot Point
Remove pivot point which prevents door lock mechanism removal.
Step 5: Remove Lock Mechanism
Picture of Remove Lock Mechanism
Remove screws retaining lock mechanism.
Remove lock mechanism from door.
Step 6: Fit New Spring
Picture of Fit New Spring
Position lock as shown, you will see from image where spring should be located, remove remains of old spring if evident.
Fit the new spring in to the round hole first, using a small screw driver prise the other end in to the triangular hole.
Test the operation of the spring and reinstall
wilgubeast (author)2014-06-10
This project made me want to improve the door lock springs in my own car. Also, I love make/model specific tutorials that cover almost 30 years of a product line. Nice work.
About This Instructable
2,586views
6favorites
More by x8rltd:Audi VW 2.0 TFSI T FSI Inlet Intake Manifold Swirl Flap Runner Delete Repair Kit Plate Blanks Install Instruction GuideAudi SEAT Skoda VW VAG 2.0 TDI Intake Inlet Manifold Flap Actuator Motor Repair Bracket P2015 Error Fix Kit Install Instruction GuideNew VW Beetle Interior Door Grab Pull Metal Handles Replacement Repair Fix Kit Install Instructions Guide
Add instructable to:
