Tools:
Sliding square
Razor blade
Center punch
Small hammer
Large hammer
Mandrel (I used a pry bar)
Rotary tool
File
Drill press
Sockets
80 Grit sand paper
400 Grit sand paper
2000 Grit sand paper
Polishing Compound
Remove these ads by
Signing UpStep 1: Mark the center
Clamp the ring. Starting with a small drill bit, drill through the premarked center. Progressively drill a bigger hole until it will fit on the mandrel your using. I used a pry bar as the mandrel.
Visit Our Store »
Go Pro Today »
I do want to say to anyone who is not aware. A *lot* of women have nickel allergies and if you make something for your love and she can't wear it, don't think your efforts weren't appreciated. I am severely allergic to nickel and cannot wear it at all. It eats my skin up as if I had spilled acid on it where it comes into contact. It used to just give me infections on my ear lobes, but has gotten much worse over the years.
My grandparents were amateur jewelers and used a "ring sizer" to get a ring to a particular size - it is basically a narrow steel cone that you place the ring on and smack it with a wooden mallet to size it and get it back into round if it is bent. I have no affiliation with this site, but they have a ring sizer for $3.50 - http://www.gossamerwingsdesigns.com/bracelet-sizer.htm..
If you used pieces of pipe increasing in size, you could shape a ring by hammering down rather than around.
To buff your ring, you could use a sanding drum mandrel like these from Lee Valley http://www.leevalley.com/en/wood/page.aspx?p=42503&cat=1,42500,42501 but you can do the same thing with a small piece of rubber air hose, a bolt, a washer and two nuts (one to squeeze the hoe against the ring blank, and one to lock it in place)
Again, Very Nice work and good Luck
I use the coin as is. You could anneal it if you want but I think it turns out fine for what it's used for.
Really, I've never tried anything other then just strait hammering but I'll give it a try and see how it goes.
I'm working on a two coin pendant. I'm hoping to have it posted before Valentines Day.
I know that Titanium is a very hard metal, yet is very, very slow to work-harden; this may also be true about the nickel coin alloy, since nickel is also a very hard metal. (Only a guess - I realize nickel and titanium probably have little in common other than both being corrosion-resistant).
Nice instructions.
Nice idea.
Great photos. (It's nice to see someone how knows what focus is!)
