Remove these ads by
Signing UpStep 1The Materials and Cost
8 - AA 1.2 volt NiMH Rechargeable batteries $6+ (depending on brand)
1 - Eight AA battery clip (4 rows of 2 batteries) $2.50
1 - small piece of aluminum foil a couple cents if you already have some
1 - 3 x 5 notecard a couple cents if you already have some
1 - roll of double sided tape $1.50
1 or 2 - stick(s) of hot glue ~$2 for a small bundle
1 - aluminum heat sink (salvaged, or new) $2-10 (depending on size and seller)
1 - switch or button a couple cents
some wire a couple cents
1 - package of high strength glue (i used JB Weld) $5-8 (this is only necessary if you use the lens
1 - focusing lens large enough for the head of the flashlight (I salvaged this from an overhead
projector, so I am not sure of the price)
Multiple resistors of different values (preferably 1/2 watt), or one 3.9 ohm resistor with a 4-5 watt
rating
1 - small tube of thermal compound grease $1-2
1 - 9v battery clip (optional)
total: roughly $27 depending on what you already have and what brands you buy
(for the batteries, thermal grease, and LED, I suggest ebay. the rechargeables are very cheap, but ive been using them for weeks with no problems yet)
Stop wasting time with 5mm LEDs. They're complete junk, only suitable for Toys, Indicators etc. If you need some practical illumination, look at SEOUL p4 Z-LED which are now available in Bombay.
I am not sure how many lumens each of those LEDs produces, but if yours are capable of 20 lumens each, your motorcycle should be quite adequately lit.
you would need 68 ohm resistors for this setup. if you'd like to see a diagram fo this, just go to: http://led.linear1.org/led.wiz
and enter your information
So you mean that with the appropriate lense or reflector I can use them as primary headlights in a motorcycle!!!
I highly suggest that you use the Cree XR-E led. You can get them on eBay for $4, and they have double the output.
Using the same battery setup (from my instructable) with an XR-E, you would need to make the resistor capable of dissipating 7+ watts.
That being the case, I suggest running the XR-E at 700 mA using a 3.6v battery pack (using batteries in increments of 3 (either 3, 6, 9, or so on)
That way, you would be able to run the led at around 200 lumens. You would need a 1+ watt resistor in this configuration.
hope that helps, and good luck!
