3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Install Component
Install Component
If you own a Honda Civic (or Accord) circa 2005 ('01-'05) you may eventually run into a problem with your fuel door not opening when you push the lever. This is a common issue and at least one person is trying to monopolize on it. http://fueldoorfix.com The problem is caused by wear and tare (rust / cracking plastic) at the connection point between the control lever and the cable that runs to the door-latch mechanism. This issue can be fixed in about 1.5 hours and for under $3; avoiding a trip to the dealership to replace the entire cable ($40), and paying for labor because your 3yr/36k warranty has expired. Here's how...
Overview of Steps
1) Tools/Materials
2) Open Fuel Door (so you can gas up until you fix it)
3) Remove Panel Over Driver's Seatbelt
4) Remove Panel Over Hood Lever
5) Remove Panel Over Fuel Door / Trunk Lever
6) Remove Fuel Door / Trunk Lever Assembly
7) Make Component
8) (Optional) Remove Crumbling Tension Piece
9) Install Component
Step 1You'll Need
You\
Tools:
- Flathead screwdriver
- Phillipshead screwdriver
- 10 mm hex socket wrench
- Dremel or Hacksaw
Materials: (found at Home Depot)
- 1/2" diameter PEX pipe (5' length found in plumbing - $1.78)
- 2 x 1/4" hitch pins (2 pack found in bolts/hardware - $0.59)
10 comments
Apr 2, 2012. 8:18 AMBobptoo says:
I tried to get to the fuel cable but had a hard time pulling back the cover after removing the plastic fastener. So I gave up on it and went to the switch up front and dismounted it as you prescribe. I found that the plastic piece was in good shape and was able by forcing the cable forward to open my fuel door. I then lubricated the cable at the plastic area and operated it several times and it worked fine. Able to open fuel door okay. Want to thank you for all the information, a great site. BobP 04/2/2012
Mar 19, 2012. 11:45 AMchinyeel says:
Great post, thanks, but as I am not too mechanically inclines and needed my tank opened and fixed. I had no choice but to leave it at Honda Markham for 1.5 hrs and they scammed me for $319.15, I know, don't say it, these dealerships are real rip-off artists. Invoice states: Parts = $84.43 & Labour $220.00 plus tax.
Dec 13, 2011. 3:59 AMdukale says:
a.gasior,
Excellent DIY instruction as well as engineering. I have 02 Accord, and your posting worked charm, saved bundle of money, and headache. I only had to use one hitch clip, but added couple of cable tie to hold the assembly in place. Total time spent was about two hours (internet surfing, trip to hardware store, part prep, and installation).
Dec 10, 2011. 2:05 PMjknaur says:
Great Fix! Saved us $200. Took a little longer, didn't have a vise, so my cuts weren't as precise as they needed to be. Took a little tinkering with the Dremel to resolve. I also found it necessary to remove the old crumbling piece to make the new one fit. Couple of points for the amateurs out there like me. The new piece fits much better if you remember to put it back under the carpet. Be careful to pull the entire assembly as far forward as you can when you are tightening the bold that holds it to the side of the car. If you don't, the lever runs into the cover when you open the trunk and you have to take all the molding off to adjust it. Thanks again! This really is a great fix!
Oct 3, 2011. 9:00 AMchirag.827 says:
Awesome... Yesterday dt: 10/02/2011, I just applied above instructions to fix the broken fuel door and it worked. It was bit tough to make component and fit cable through hitch pin but overall - I appreciate and thank you for saving my $150.
Jul 30, 2011. 6:11 PMmreds1 says:
Thanks a.gasior! This was an excellent post. The instructions couldn't have been more clear and exact. I did everything as you indicated and it was a piece of cake. I did use my table saw with the blade set to 1/8th inch to cut the slots. My total cost was about $5 and it took me about an hour. Works like a charm. Nice to know that I wasn't putting out $150+ to Honda. Cheers!
Apr 17, 2010. 1:09 PMjeffcohen123 says:
Very clear post. I have an 01 civic, and the same instructions apply. Thanks for posting this! Saved me a bunch of cash.
Feb 6, 2010. 2:12 PMshantinath1000 says:
What a drag that I found this today in stead of a month ago.  I had the same problem and had the dealer fix it a few weeks ago.  Nice 'Ible by the way.
Jan 10, 2010. 10:24 AMskatawandi says:
What a great solution! Took me about 45min and about 4 dollars for parts. The best thing is, the fix appears to be permanent! I would make sure to add the zip tie holding the PEX pipe in place; it tends to slip out otherwise.
Aug 16, 2009. 10:40 AMfirdawsi says:
What a great fix! I only wish I had a Civic to apply it to :(
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:a.gasior
