my motivation for this began when my 17" monitors molded cable broke internally leaving me with no monitor, and seeing as i could not just buy a replacement cable i decided to explore inside to see if i could fix it, upon looking inside i thought it cant be that hard considering i have little experience soldering.
so i set to work and these are my results
Remove these ads by
Signing UpStep 1Tools you will need
1. philips head screwdriver
2. pocket knife
3. soldering iron
4. cored solder
5. tin snips
6. heat gun
7. an old vga graphics card
Clean up with a small file. If you have a high speed rotary tool, thats useful for clean up too, but it could also be used to cut the tin, with a thin grinding type wheel, I do a lot of that, works good, as long as take your time, overheating the tin cause distortion.
File=== who do you know that has a nail file? But don't get caught
And be aware that tin snips have a habit of twisting tin.
But whatever way you do it, be aware cut edges unless rounded off, can and will cut insulation on wire, can lead to short circuits.
A tip, its very hard to strip insulation of thin wire, I use lots of telephone wiring, the sort used inside walls between jack points, in my projects, safest way to strip insulation, is melt it off with a soldering iron, in emergency, with no soldering iron, I have used a match, or the cooking element on a stove/oven.
