Fix It: Squeaky Door
Published
Introduction: Fix It: Squeaky Door
This technique to fix any squeaky door uses only WD-40!
Step 1:
Using WD-40 completely spray the hinge.
Repeat on all the hinges to guarantee a squeak free door.
Step 2:
Open & Close the door to work the WD-40 deep into the hinge.
Step 3:
Use a rag or paper towel to wipe up any grim that came out of the hinge.
Step 4:
Enjoy a squeak free door!
WD-40 can protect your bike & tools, remove grease, and lubricate locks, hinges, & all moving parts
WD-40 removes paint, gum, rubber cement, grease, grime and more
WD-40 loosens and penetrates rusted or stuck bolts and plumbing joints
WD-40 has Many more uses! Go to WD-40.com to learn them all
    • Oil Contest
      Oil Contest
    • Make it Move Contest
    • Casting Contest
      Casting Contest
    2 Comments
    Do not use WD-40 for lubrication! WD means Water Displacement. It's main use is solvent and rust dissolver. The lubricant-like properties are mainly from components in WD-40 that evaporate quickly and therefore won't last for long.
    So use WD-40 to clean up the previous lubricant and then apply proper one.
    You can also use graphite and it won't attract dust and devris
