Super Power Soldering Gun for Continuous Use! Fix Overheating
775
10
5
Posted in TechnologySoldering
Introduction: Super Power Soldering Gun for Continuous Use! Fix Overheating
These soldering guns they are great but they can overheat.
The label says "1 minute usage time" and "4 minutes for cooling".
So if you want to put a normal computer fan go ahead, very easy to do, and you can use masking tape and be done in 4 minutes.
It was not enough for me, so I put a high speed fan for extreme cooling. I used a brushless motor and printed a fan on the 3d printer, and printed a case, materials used below:
  • 12V power adapter
  • Servo Tester
  • 10-20A ESC
  • Power the world motor
The links will be in the last step when you are ready to get started.
Step 1: 3d Printed Fan.
The fan and case are drawn, and then 3d printed. I was not sure if it would work or if it would spin and explode, but it works beautifully and I did not have to do any balancing, only the normal clean it up after the print.
Here is a video for proof : https://www.youtube.com/watch?v=lPghH_uB9Y0
Step 2: So Build Something
Now that this has more cooling you can work on projects for that much longer.
The links to the parts list is right here.
buzzebike.com/FanPartsList.html
At the bottom of the list you can get ALL the parts at once, in a kit, while simultaneously supporting me on the next kit design.
I am trying to build more useful things and if you have anything to request, please do!
    • Science of Cooking
      Science of Cooking
    • Pocket-Sized Contest
    • Microcontroller Contest
    5 Comments
    dude iTS awesome
    Pleace do me a fafore, ad an smoke extruder,to your solder tip,next to iT
    So iTS desmoke iT and attached to the 3D printed housing,( so e sort of tubing)
    So iT blows out from iT. But you must place a piece of corbonfilter, for the toxics.
    Good idea or not?
    for sombody reply About blowing out, or so
    Witch direction iT wil blow the smoke to iTS not relevante the corbon wil do iTS Job.
    Becous This fan is blowing, in the iron to prevent heating
    but i whas easier with an 12v fan of a pc, so you have a simple conection on the solder irons bord itself.
