3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Fix Streaks on Lexmark C500
Vertical streaking is a common complaint among owners of Lexmark C500 series color laser printers. This can be caused by a buildup of toner deposits inside the toner cartridges. It is possible to service these cartridges to wring some more life out of them.
First, prepare your work area. I put the cart down on a few paper towels, as you will be spilling a little toner. I also have 91% alcohol, some cotton swabs, and a small phillips head screwdriver.
Step 1Remove the baffle
Remove the baffle
Hold the cartridge with the roller side up. You should be able to see where the streaks in the toner on the roller. The layer of toner should be as even and solid as possible.
First take the 5 inside screws off of the baffle. Be careful not to touch or scratch the roller. These screws are short. They hold the blade assembly to the underside of the carriage. Don't apply too much pressure to these screws.
5 comments
Feb 1, 2010. 6:16 AMAlfredo26 says:
Thanks!
I have a new printer now.
BTW if you use some cotton with a few drops of thinner the blade will be like new with no pain in just 1 mississipi .
Jan 24, 2010. 6:45 AMmdog93 says:
You should be very careful when doing this, toner dust is a carcenagen!!! (meaning it can give you cancer if you breathe it in) so i wouldn't recommend doing this at all but if you must i would highly recommend wearing a dust mask and possibly latex/ vinyl gloves.
Jan 25, 2010. 2:11 PMmdog93 says:
well hazard could mean leads to any disease, because i'm sure they wouldn't write it's a carcenagen anyways cause nobody would buy it.
Jan 25, 2010. 8:23 AMdchall8 says:
I really like this.  I have a different printer but the same principles apply.  Take it apart (carefully), clean it, and put it together (more carefully).  I did this with carburetors back when I was a kid so why not now with my electronic toys?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:greensweater
