Fix Your Westinghouse SK-19H210S Television
 by mk650g
My nice little 19" Westinghouse TV lasted just over a year before it died. It had been working beautifully until one day, it refused to turn on. The little power LED wouldn't even flicker. I called Westinghouse and they said that I was out of luck because it was no longer under warranty. Shoot.
After some Googling, I discovered that my particular model (SK-19H210S) is notorious for this exact problem. Every review I read told the same story: "It lasted a year and then died! Westinghouse told me I was S.O.L.!"
Time to break out the ol' screwdriver and take a peek under the hood.
My first suspect was the power supply board. Possibly just a blown fuse? After taking the TV apart, and inspecting the power supply, I found the culprit: a bad 2200uF capacitor. One lousy capacitor goes and the whole darn TV is useless! Sheesh...
I have a sneaking suspicion that Westinghouse bought a got bad batch of capacitors that only lasted for a year. If I am correct, than replacing this one little part could revive your poor little TV!
These instructions are intended for only this specific model of TV. Even if you do have the same model, it is still possible that the problem is something completely different. It might be worth a shot though. The worst you could do is break it. If its already broken then whats the difference?
A word of caution: You may encounter high voltages! Capacitors can store a lot of electricity. It is a good idea to discharge capacitors by shorting out their leads with a plastic handled screwdriver. Wear safety glasses while doing this!
Skills:
Basic soldering
Tools:
Safety glasses
Multimeter (for checking faulty components)
Phillips screwdriver
Plastic pry bars (For getting the case apart without scratching it. An old credit card might work too. Try a butter knife if you don't care about scratches)
Pliers
Tweezers
Soldering Iron
Towel (to keep the screen from getting scratched)
Hammer (for if it doesn't work and you get frustrated)
Materials:
Solder
One 2200uF 16v Electrolytic capacitor
Aluminum foil tape (duct tape or Gorilla tape might work in a pinch)
Cost:
FREE (if you scrounge, $3 at the most if you don't)
If you have all the tools, then all you need is the replacement capacitor. I scrounged one from my pile of electronic junk.
If you don't have one on hand, try a local hobby shop or RadioShack. I did a quick search on eBay and found a lot of 5 for $2.50 including shipping.
Just make sure that the one you're using is a 2200uF electrolytic capacitor with a 16v working voltage.
Step 1: Case Disassembly
Getting the case open can be tricky. Just pay attention to how it all comes apart because you will have to put it back together when you're done! Pay attention to which screws came from which holes.
If you are an experienced TV-disassembler, skip to step 7.
Tips:
It helps to keep small parts in a dish or a cup.
Taping screws to a piece of paper and writing notes helps you remember where they go.
Marking or labeling parts and wires as you take them apart is helpful when it comes time to reassemble.
First, remove the front speaker cover by prying it downward. It is just snapped on, no screws.
kikitxus says: Nov 12, 2012. 3:38 PM
Does anyone know the order of the back lite wires connectors ?
i replaced the bulgingcapacitorr , now i turnTV on an the screen lights up an then off ?have sound but no picture after start up .
ralphj1 says: Sep 1, 2012. 4:37 PM
A plastic tool isn't really necessary. Bare hands work exceptionally well. Apply pressure with your thumbs to release the locking tabs. Very well written. The 2200 uF cap was bulging. Was 10V part!
TheMel says: Aug 1, 2012. 6:35 PM
Exactly the problem. It took me good part of an hour to dismantle the goddamn plastic assembly and I broke one of the latches but they are too many anyway. One missing will not make a difference.
Now, I need to find in which box I stored my soldering iron in as I recently moved as well as a place to get the replacement capacitor. Can't thank you enough. If it was not your article, I wouldn't figure out how to disassemble this monstrosity and most probably chucked the whole thing into trash. Yay...
vidalesluis says: Jul 27, 2012. 9:32 PM
Hello! now i was following your instructions as i stumbled into this problem as i worked my way through step 5 i noticed the four wires that should be on the left were actually six wires the two extra wires belonging to an extra backlight that apparently was put there by the person who tried to fix it before me. now my question here is would you happen to know how the wires are supposed to be connected??
Mistro116 says: Jul 4, 2012. 9:10 AM
Thank you so much for this great tutorial. I bought this TV many years ago, and it died on me. Been meaning to get around to fix it, followed your instructions, and it worked marvelously the first try! Cost me $0.25 to get the capacitors from China, and they gave me an extra 9 of them for free :) Thanks again!
catfly911 says: Jun 10, 2012. 5:14 PM
I have the same model, however I have no sound, so you think the repair would be the same... or could this be a fuse problem?
catfly911 says: Jun 10, 2012. 5:13 PM
I have the same model, video is working but have no sound... do you think the repair would be the same?
MasterofNoneJr says: Apr 22, 2012. 9:23 AM
Fixed it!! I too had the same capacitor failure. Was going to trash the TV but found your instructions with a Google search. Step by step with photos was just what I needed, since I had never disassembled a TV before. Had to order the part via ebay because the nearest Radio Shack did not carry the 2200 uF capacitor. Bought 5 online for $4.79 with free shipping. Thanks for posting. I would not be afraid to do it again.
jpridgen says: Dec 8, 2011. 10:58 PM
Please help. I'm having trouble reconnecting the ribbon cable to the switch assy in ( Step 4 Unplug controls). The large ribbon inadvertantly came loose (on the "box" end) but that connector had a small flap that I lifted and slid the cable home and then pushed the flap back down, but if the switch assy connector has a flap, I can't lift it up without fear of breaking the connector. Is there a flap on that connector too?
By the way the 2200 mfd cap is bad on my tv too. Your help will be very much appreciated. If I can't reconnect the flat ribbon, then all my efforts are in vain.
Thanks
mk650g (author) in reply to jpridgenDec 8, 2011. 11:06 PM
There's no locking flap on the switch board. Its just a friction fit.
Push the cable back into the slot until it feels like its gone all the way down. Just don't force it and make sure its facing the right way.
Good luck!
elcaminoguy in reply to mk650gMar 14, 2012. 6:49 PM
I did but its not making a connection as the Picture wont come on it does go in & stay there just not making a good connection.I have undone it & reinserted it at least 10 time.It does power on now which it didnt do before replacing the Capacitor just no picture just a white screen.
elcaminoguy says: Mar 14, 2012. 6:46 PM
This was a Big Help I got Power back But Picture wont work because ribbon cable wont connect.I was hoping by now someone would have been able to help.I guess nobody has a cure.
elcaminoguy says: Feb 20, 2012. 6:18 PM
I too have the big ribbon cable problem it dont want to stay in.
gottadoitmyself says: Nov 27, 2011. 3:52 PM
Great article! Just used it to fix my son's monitor. Replaced all the capacitors that showed signs of bulging at the top and one that was leaking. The replaced originals were all CapXon electrolytic high temp (105c) capacitors: (2) 1000uF 25V, (2) 220uF 25V, (1) 2200uF 10V, (1) 1000uF 10V. I ordered the following replacement high temp radial capacitors from Parts Express via Amazon for $11.69 which included shipping: (2) 1000uF 25V, (2) 220uF 25V, (1) 2200uF 16V, (1) 1000uF 16V. I substituted the 10V with 16V. A lot cheaper than buying a new monitor. Thanks again.
dbard2 says: Nov 16, 2011. 4:14 PM
This guide was spot on. YOU ROCK!! Took a chance buying the capacitor before disassembling, but the culprit was definitely visibly bad. Your guide has given my TV life once more... THANK YOU!!!!!!
1099 says: Jun 6, 2011. 2:08 AM
U R the man!! Got a small issue here. My cap says its a 2200uF 10v. Did you originally start out with a 2200uF 16v or bump up to it. U R still the man.
Thank U
mk650g (author) in reply to 1099Jun 6, 2011. 11:12 AM
The original was 16v. You could probably get away with a 10v cap, but there is a chance that it would get fried because it is rated for a lower voltage. I don't think it would hurt anything besides the capacitor itself. Its worth a try, if it doesn't work, you're just back where you started.
Happy to help! I hope it works
laleck says: May 21, 2011. 3:13 PM
Worked like a charm, cannot thank you enough for posting this. My grandma is going to be so happy her tv is fixed. Took me about 2 hours, would have taken less if I hadn't botched the 5th step. For some reason, I thought I had to completely remove the foil surrounding the thick ribbon cable, woops!
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
