3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Fix a Broken XBOX 360 Wireless Adapter
Step 2Open the Case
Open the Case
   This is a hard job that will take time and a lot of carefulness. There are NO screws holding the case together. It is merely plastic melded together. Begin on the short end of the adapter near to the antenna. Insert your knife into the crack that is around the adapter, and begin prying it apart. This will not be easy, be careful not to slip and cut yourself. Also, be careful not to put your knife very far through the case because there are electronics inside that you do not want to harm.
   You may have to pry all around until you find a weak spot that will pop open. (on the one I did, the top side of the adapter opened the easiest) Once you have one area open use your two screw drivers to pry along the outer edge, insert one and twist it to lift the top, then insert the other and twist it, continue this all the way around until you have the top piece separated from the bottom. The inside should look like the second picture below.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:unlerico
