Step 6Put it Back Together
-Put the board back into the bottom side of the case, routing the new wire out, via the same way that the old one went out.
-Slide the antenna back into its spot and gently reconnect the antenna wire to the board.
-reattach the top of the case in whatever manner you deem best.
I wanted to be able to get mine apart again easily, so I just wrapped some string tightly around the case. I also used the string to hold the cable in place to keep it from being pulled on since there is no “stopper” on the cable to hold it in place.
I would think that if you want yours to look more professional, that you could sand the edges of your case (before you put the circuit board back in) and then super glue the top back on once you have all the guts back in working order.
where I think it is too expensive
two buy a usb wireless network adapter for my xbox 360 er old xbox
ps I am from Denmark and go the price is from 500 to 1000 in Danish kroner do you think about it?
